If you’ve ever tried to laser flexible rolls of material you’ll know it can be really annoying to setup in the laser cutter.
Most of the time we use magnets, but then you have to make sure the magnets are clear of the work path — and then you end up wasting extra material… It’d be amazing to have a vacuum table that just sucks down your work piece to keep it in place! As it turns out, it’s not that hard to make!
After getting frustrated lasering warped material themselves, [Martin Raynsford] and the gang decided to make their very own vacuum table — using a laser cutter of course. Continue reading “DIY Vacuum Table Makes Lasering Even Easier”
