Yes, even the venerable Technics 1200 turntable can be improved. This simple, completely reversible, modification removes the automatic pitch lock from the mk2 model. If your decks have seen a lot of use the true zero point has probably drifted from the one marked on the scale. This is easy to tell by observing the strobe. If the large dots aren’t stationary when the zero is locked, you’re out of adjustment. The other nuisance is that you can’t do minor pitch adjustments when you are close to zero because it constantly wants to lock. Even if you don’t want to mod your turntables this article does show you where to go to move the zero pitch back to the actual zero.
Subscribe for weekly videos
About time! And here, I thought I was the only one dreading the spot in the mix where I hit the “+-2 blackhole”.
oh no my 1200s are fucked.
wicked! not got the same decks, but fanx 4 the link ;)
anyone else had a their decks randomly speed-up about every couple of minutes? thinking it might be the quartz :S
ooook oooook!
monkeyboi
omg, i don’t think i’ve ever seen a hack so old…
How do I make a dvd out of a dvd with only one slot for dvd I have a
IMacG5 Can I save the movie on the desktop and then copy it over.
I don’t wan ‘t the dvd to take up all my memory I have a lot to record
Any suggestions Thanks!
This Mod is Bogus. All it did was reset my pitch gain to normal (instead of it being maxed out like I had it). To really do this is a pain in the ass… http://music.hyperreal.org/dj/pitch_slider/#Rem
Honestly I don’t know if this one works either. For know I’m stuck with the quartz lock.
Awesome tutorial! Everything worked perfectly. I even went so far as to rip the ball bearings out of my sliders. I also went along and wrote a tutorial on similar as well… check audio-recording.co.uk for details.
Thanks again!!!
hello i was wondering do you have a mod’s for the brake on a turntable design technic1200 mk2 or the mod how to make a technics 1200 mk2 clone so then thank yoy and i really injoy you site
