DIY Super Soaker
With summer just around the corner you should try out a build like this constant pressure water gun that [JLspacemarine] put together. Similar to the commercially available Super Soaker toys, this isn’t just a squirt gun but includes a water reservoir as well as a pressurized air chamber. Pumping up the air chamber allows for a constant stream when the trigger is depressed. [JLspacemarine] used a combination of hardware store items such as PVC, ABS, springs, hose clamps, and valves to bring this all together.
[Thanks Danukeru]
Comments
  1. stormdog says:
    Nice. Creative use of off-the-shelf products.
  2. jeditalian says:
    i couldnt do all that. mine would be tethered to an air compressor and a water hose. and it would hurt.
  3. thenameisbam says:
    this would work well if you were in http://www.streetwars.net/
  4. nubie says:
    @jeditalian
    He is planning that next if you read the site.
  5. Smithy says:
    By the way way..The reason the super soaker is not that powerful is that it will take your eye out..like literally dude…
  6. jeditalian says:
    yeah i know lol
  7. mike says:
    I had one of these when I was a kid 50 years ago. It was a good idea then too. Not so much a great novel hack now though, but great ideas need rediscovery every now and then.
  8. j9 says:
    Yea, its nice, but it ain’t no flamethrower…
  9. grofwomp says:
    That site is pretty great. Check this build out:
    http://www.sscentral.org/homemade/supercannon2.html
    It’s a genuinely scary water gun which, apparently, releases 500oz water per second and shoots 70 feet. The build is very nicely documented too.
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
