DIY Super Soaker
With summer just around the corner you should try out a build like this constant pressure water gun that [JLspacemarine] put together. Similar to the commercially available Super Soaker toys, this isn’t just a squirt gun but includes a water reservoir as well as a pressurized air chamber. Pumping up the air chamber allows for a constant stream when the trigger is depressed. [JLspacemarine] used a combination of hardware store items such as PVC, ABS, springs, hose clamps, and valves to bring this all together.
[Thanks Danukeru]
9 thoughts on “DIY Super Soaker
  1. I had one of these when I was a kid 50 years ago. It was a good idea then too. Not so much a great novel hack now though, but great ideas need rediscovery every now and then.
Leave a Reply to grofwomp Cancel reply
