High speed video is everywhere these days, but the cameras and necessary equipment is a bit out of reach for a hobbyist. [Bassam] found a compromise and came up with a way to shoot high-speed photographs using a sound triggered flash.
[Bassam] started off by taking apart a disposable camera for the flash bulb and capacitor. After that, a circuit was designed that picks up a signal from a microphone, compares that to a preset threshold, and then uses a 555 timer to trigger the flash. The shutter of a DSLR can be left open in a dark room, so all that is needed to capture a moment in time is the snap of a finger. [Bassam] also posted gallery with the fruits of his labors.
Although this isn’t the first time we’ve seen a high-speed camera hack, the simplicity of [Bassam]‘s build is impressive. He designed a single sided board for his circuit, and the parts are very common so it should be an inexpensive build.
Subscribe for weekly videos
“but the cameras and necessary and necessary equipment is a bit out of reach for a hobbyist.?
wut?
Cool post :]
You can expect to pay £10,000+ (usually a lot more) for a half decent high speed camera.
Just hiring the Phantom HD will set you back about $2000 a day.
http://z-p-t.pl/2011/07/29/zdjecia-w-ulamku-sekundy-wyzwalanie-dzwiekiem/ Similiar project with photos and some analysis.
see also the Photoduino project
Nice project, I like how it uses cheap off-the-shelf universal (internationally available too) parts.
Amazing project! Simple and genius!
Way to go Bassam!
How can we purchase it?
