Ghostly images appear thanks to projections on fog
This wire-frame cube appears to be floating in mid-air because it actually is. This is a project which [Tom] calls a Laminar Flow Fog Screen. He built a device that puts out a faint amount of fog, which the intense light from a projector is able to illuminate. The real trick here is to get a uniformed fog wall, which is where the laminar part comes in. Laminar Flow is a phenomenon where fluids flow in a perfectly parallel stream, not allowing errant portions to introduce turbulence. This is a favorite trick with water.
[Tom's] fog screen starts off with a PC fan to move the air. This airflow is smoothed and guided by a combination of a sponge, and multiple drinking straws. This apparatus is responsible for establishing the laminar flow, as the air picks up fog from an ultrasonic fogger along the way.
The only real problem here is that you want the projector shooting off into infinity. Otherwise, the projection goes right through the fog and displays on the wall, ruining the effect. Outdoor applications are great for this, as long as there’s no air movement to mess with your carefully established fog screen.
You can find a short test clip embedded after the break but there are other videos at the link above.
Comments
  1. anon says:
    Looks nice. Commercial laminar fog screens at http://www.fogscreen.com
  2. MikrySoft says:
    Ok, I see two links – one to wiki, other to older HaD post. Where’s link to the project?
  3. John C. Reid says:
    The speech bubble with the binary on the wall has a 2 in it.
  4. Gabe R. says:
    do you think a second projector/screen set perpendicular to the first would achieve a 3d effect?
    I recently picked up a pico projector for work. I might have to try this out.
  5. · says:
    The picture on the wall appears to be from London Hackspace. A source link with more information would be nice, but with hundreds of projects, maybe one on their wiki could be this?
  6. Dan says:
  7. grenadier says:
    loldongs
  8. Mattster says:
    Memories of Seaquest DSV and the actor W. Morgan Shepard who portrayed the holagram in the laminar flow fog
  9. Roger Wilco says:
    OMFG!
  10. bothersaidpooh says:
    “Help me Obi-Wan Kenobi, you’re my only hope”…
    in 3…2..
  11. Polymath says:
    Glad to see someone beat me to the Seaquest DSV reference. I thought I was the only one that watched much less remembered it. So how long before we see this adorning gas station counters advertising male enhancement products and energy supplements?
  12. Polymath says:
    Also, this is pretty cool. What he using to generate the fog?
  13. TheHypnotist says:
    love the hacks tom. <3
  14. Stu says:
    Cool, has been done before tho.
    As for those who think this is some kind of hologram, a la Seaquest, or an R2D2 projector, forget it, its not actually fully 3D, only a 2D projection on a non-solid flat display.
    …Would be cool, then, to combine, say, 8 of these in a line, to give you a kind of pseudo 3D! You’d then have to project each ‘layer’ from a sheer (shear?) angle from below to keep all the layers close to each other and to prevent images from hitting the wrong ‘screens’.
    Then again, could get clever, and somehow project 8 images from the same direction, focused for each ‘screen’. That special multi-focusing camera image software trick done recently springs to mind.
  15. JD says:
    Booooo Forget the Text Get a girl to say
    “Help me, Obi-Wan Kenobi; you’re my only hope.”
  16. disgustipated says:
    this is where 3d movies and things should be going. enough with the eye tricks and digital gimmicks, give me something with real depth.
  17. Bill Jacobs says:
    Picture on wall Blue Robot? anybody?
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
