Building a DIY GPS cube
Originally, [Karman] wanted to build a speedometer for his bike. Feature creep makes fools of us all, so after a month of work [Karman] had a  GPS-enabled cube that tells him his current latitude and longitude, current time, course, direction and speed.
[Karman]‘s GPS cube uses a cheap GPS module, Arduino Mini Pro, a magnificent OLED display, and a LiPo battery salvaged from a first gen iPod nano. Surprisingly, the build is very clean – there are no wires, headers, or random epoxy globs sticking out everywhere. The entire build is just a bit larger than one cubic inch, allowing [Karman] to carry around the power of a GPS device in his pocket.
The code for [Karman]‘s GPS cube uses the TinyGPS library for Arduino, that has a few great functions that track the number of satellites visible and report the current time. Now all that’s left to do is fabricate a case for this awesome little project. As always, video demo after the break.
Comments
  1. ino says:
    that’s really nice !
  2. Mark says:
    That’s a fun project – nice job.
  3. HackerK says:
    Nice build!
  4. Scott says:
    Weren’t the batteries in the original iPod nano recalled?
  5. JB says:
    Cool build! Question: does it adjust for DST automatically?
    • KaR]V[aN says:
      No but I think that would be easy to code as you already have current date.
      By the now, for example, I’m +1, but for daylight saving we are currently +2, so i just add 1 in timezone setting.
  6. Steve says:
    Does it have data-logging capabilities? Would it be possible to add a microSD slot in the cube?
  7. Peter P says:
    This would be great for a cat tracker, After reading a few projects of people tracking there cats, I feel like this is purrrrfect :-D. Just need to find a camera solution now
  8. mikekorostelev says:
    Anyone know of a small GSM board that can be used with this? This is really cool
  9. mikekorostelev says:
    Anyone know of a small GSM board with gprs that can be used with this?
  10. soopergooman says:
    wonder if i could take apart a psp gs receiver and recreate the same thing?
  11. kidna says:
    Damn! have been having this idea for months! well done! Now put a stop-watch on it and it will be perfect :)
  12. Joachim says:
    Will it also work with other GPS modules like the popular ST22 ? I got several of these for $20 each at perthold.de
    I am also wondering if it could adjust the time depending from the time zone you are in. I mean it has the GPS position so it could figure out somehow which timezone it is ?
  13. TiredJuan says:
    What OLED screen are you using?
  14. n0lkk says:
    Nice for more “feature creep”,if licensed, add a TNC along with a transceiver operating on 44.390 MHz. Or a transmit only tracker if one wishes.
  15. Threeck says:
    WOW this is so cool! now put in a usb-out on that so you can view your stats on your PC (with matching maps to further visualize you position) ^^
  16. gr4viton says:
    please try to make a compenion-cube-like case :)
    please please please!
  17. Mental2k says:
    Attaching a GSM module would let you use it to track stuff. Fantastic the whole project is fantastic!
  18. Bhavna says:
    Will it be possible to now plot the coordinates obtained on some map, say google map?
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
