Building a pick and place with 3D printed parts
For the last few months, [HeliumFrog] has been building a SCARA bot to serve as the basis for a pick and place machine. Somewhat amazingly, this is the first robot of its kind to be printed on a 3D printer.
A SCARA-type robot is an articulated arm perfectly suited for transferring components from tubes and reels to a PCB. [HeliumFrog] began his build with an arm with large gears in joints driven by stepper motors and toothed belts. The Z axis was originally driven with a lead screw, but after a thoughtful redesign that was changed over to another toothed belt.
We’ve seen our share of DIY pick and place machines, but most of those have been based on a traditional X/Y Cartesian frame. [HeliumFrog]‘s SCARA bot should be – theoretically, at least – faster and more accurate while taking up a smaller footprint in the workshop.
[HeliumFrog] is more or less done with the basics of his build, and is now moving on to building a plastic extrusion tool head for his SCARA bot. Very cool, and should make this robot capable of self-reproduction for under £400 (~$600).
You can check out a video of this articulated arm bot after the break.
Thanks, [Kyle] for sending this one in.
Comments
  1. Zee says:
    This is very impressive. If the software is also up to the task I can’t wait to see one of these assembling a PCB
  2. xxz3r0x says:
    Can anyone one print me a 3d printer with their 3d printer yet?
  3. zanginator says:
    This is impressive to say the least!
  4. DerAxeman says:
    If HeliumFrog can pull this and get the accuracy required I’ll be very impressed. With some of today’s fine pitched I can’t imagine how it can be done without the tight tolerances of machined parts.
  5. K!P says:
    impressive!
    On a side note, does annyone know the software he is using for the assembly drawings?
    (still hoping to stumble upon a great freeware mechanical assembly tool), found NaroCAD and FreeCad so far, doenst seem to handle assembly’s (haven’t looked real close tho)
  6. adr says:
    Great build!
    Why do you think that this type of robot is “perfectly suited for transferring components from tubes and reels to a PCB”, as say compared to the traditional x/y positioning?
    Also, re precision the proof is in the pudding. I didn’t see anything in the article that qualifies this more for repeatable precise positioning than any other 3D printer, plotter or CNC project.
  7. RunnerPack says:
    We saw a commercial version of this kind of arm recently, I believe:
    http://hackaday.com/2012/06/19/salvaged-robot-arm-makes-a-big-3d-printer/
    They should make a pick’n’place head for that sucker…
  8. Mike says:
    Excellent build. Impressive work. The pencil tracked the impressions well.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 92,099 other followers
