We see projects here all the time that blend computing with the real world. Some people are naturally stronger on the mechanical end of things, whereas some are better with electronics or coding. All three specialities can be needed depending on your project. If your weakness lies in making a computer do your bidding, I might suggest that the Python language is a good one to learn.
I’ve been going through Learn Python the Hard Way, which is offered for free online, or you can pay for it if you so choose. I’ve published my thoughts on lessons 1-10 and 11-20 so far. As a mechanical engineer with limited (but not totally nonexistent) programming skills, it’s been an excellent experience so far.
If you’re wondering if Python is a good language to learn if you’d like to participate in [HAD] style projects, why not check out the following projects featured here:
- Light painting bar using Python to translate a picture into Arduino code.
- Writing Python Drivers for Input Devices such as a joystick.
- Splunk LED Meter external system data display.
Or just do a search of [HAD], and you’ll find many other projects for inspiration. If you’ve got a Python project to share, be sure to tell us about it in the comments!
Subscribe for weekly videos
Great place to learn python, udacity.com
Blinking LEDs is not hacking
Why do you think blinking LEDs is not hacking? Have you seen my blog?
No it isn’t, but writing a driver in a fast to develop scripting language is an awe inspiring one.
Have you seen my blog? Why do you think this does not constitute hacking?
BTW: in my forthcoming book I will blink 20 LEDs with 256 brightness levels @>20kHz. Althoug the Arduino runs at 16MHz and has not hardware support for this I manage to keep CPU utilization below 65% thus allowing to compute the output on the fly. Try yourself and then explain why blinking LEDs is not hacking.
Device drivers are mostly boring.
Take this:
PYTHON
>>>e = lambda x: lambda f: f(x)
>>>e(e(42))(e(lambda x: x))
I use Python a fair bit in physical projects :-
http://www.madox.net/blog/2011/01/24/mecanum-wheel-rover-2/
It is even handy to use for making of physical objects :-
http://www.madox.net/blog/2011/10/11/image-to-svg-cutout-script/
ive always been a lua kind of guy when it comes to interpreted code. never hat to learn python yet. frankly the strict whitespace usage would drive me nuts.
My favourite abbreviation of python is “pft”
I use python in my day job, but I’ve also used python to write code for the OWI EDGE USB robot arm – it only came with a rather rubbish windows CD, and using PyUSB I’ve got code that will work on Win, Lin and Mac. Once I’d found some data on the protocol the arm used for its USB stuff, it was an afternoons work to get it to move blocks. Having no sensors as it came, there was a lot of fiddly time based stuff – I am working on adding sensors to it…
When I have to learn a new programming language, I usually fire up my text-editor, my browser, and start programming with the help of google.
I’ve just started to learn Phyton two weeks ago (comming from PHP), and now I’ve already written a programm containing 1k+ lines of code.
I’ve found out that I haven’t got the patience to read long, boring books, so I just start to code (trial and error). In the first few days, it’s really a PITA to get used to the syntax, but after that it’s just a matter of memorizing all of these functions.
I’ve been learning Python in spare moments reading “Byte of Python” by Swaroop C H.
http://www.swaroopch.org/notes/Python
