Programming a microcontroller one bit at a time
Imagine you’re stuck on a desert island, hundreds of miles away from the nearest person, and you finally have time to finish that project you’re working on. You have a single microcontroller, but you’re lacking a computer and you need to program an ATtiny13. How do you do it? [androidruberoid] figured out how to manually flash a microcontroller (Russian, surprisingly good translation) using just three switches and a lot of patience.
[androidruberoid]‘s ATtiny13 – like nearly all Atmel microcontrollers – are programmed using an SPI interface. This interface requires four signals: SCK, a data clock, MOSI, the data line from master to slave, MISO, data from slave to master, and RESET. By connecting these data lines to buttons, [androidruberoid] is able to manually key in new firmware one byte at a time.
This technique of manually programming bits relies on the fact that there is no minimum speed for an SPI interface. In the video after the break, you can see [androidruberoid] manually programming an ATtiny13 with a simple program. It only lights up an LED, but with enough patience he could key in a simple ‘blink a LED’ program.
Comments
  1. slowJim says:
    Very geeky but very cool
  2. ChalkBored says:
    With a little more effort, he could make a card reader.
  3. Bill rowe says:
    Exceptional. I love spi but i would never have thought of this. Debouncing the clock would be critical!
  4. Dave says:
    Now that’s what I call bit-banging(!)
  5. Frank Cohen says:
    This is what McGyver would do.
  6. Alex Rossie says:
    He should have made a simple programmer, bootstrap that shizzle
  7. Eirinn says:
    So basically he finger banged a uC until it lit up?
  8. Coda says:
    One bit at a time, not one byte. SPI is a bitstream.
  9. Philippe says:
    That’s bit-banging… your head on the walls. Imagine if you make a mistake! :-)
  10. willrandship says:
    That’s even more error-prone than punchcards. :P
  11. ferdinand says:
    this is fun but it take a lot of time. to use this techniek or you have no live (even more than a WoW,er)or you in deadrow whit all time
  12. AussieTech says:
    Groovy! +1 (Ah, memories of when the Alpha-16 Mini “blew the boot” and 16 words had to be manually loaded via the front panel switches).
    Not to detract from this sweet hack, but might I respectfully suggest that bit-banging the control lines on a parallel or serial port on an old clunker PC could be more practically (and less frustratingly) employed by slightly less isolated hackers?
  13. Sixten says:
    He needs a Supercoder2000
    http://www.techeblog.com/index.php/tech-gadget/feature-funny-keyboards-supercoder-2000-
    It also reminds me of this Dilbert comic
  14. TacticalNinja says:
    It’s just a matter of interfacing a uC to interpret those signals and you can use just about any device to program a chip. I mean, send data to a bluetooth enabled arduino from an Android to bit bang those data, and you’ve got a wireless portable programmer of some sort.
  15. ApexLogic says:
    He’s on a metaphorical island people. Once he flashes his ATtiny he will proceed to make a coconut radio.
  16. Arm-eee of 1 says:
    Ok so the appropriate upgrade would be a robotic arm that does the bit-banging?
    With appropriate processor, would be an arm for an arm — costing an arm depends on which source one uses :D
  17. saimhe says:
    Now this is a truly DIY-friendly programming interface that makes such things possible. Way to go, Atmel!
  18. RaMu says:
    I made a similar project to this, but I used one pic to program another pic, it has similar working prensip, I have gave my all codes and schematics in microcip site If there were anyone who wanna see or build may look at this link http://www.microchip.com/forums/f162.aspx and if hackaday wants to publish it in the site I may also added a working video of it.
  19. Greenaum says:
    Would be nice to semi-automate the clock line, have 2 buttons, “0” and “1” (made of palm tree leaves), and have the clocking do itself on each keypress. A couple of gates or something could handle that. Then he could put the bits in slightly easier. Tho I suppose it’s not supposed to be easy.
  20. Azariah says:
    Hi I need someone to program me a microcontroller (looks like ATtiny13) running on this board
    http://dx.com/p/8-mode-p7-led-driver-circuit-board-for-flashlight-dc-2-8-4-2v-106799#.UxomUPl_tsg
    or another board here
    http://www.lightscastle.com/product/17mm-2800ma-5-mode-memory-regulated-led-driver-circuit-board-for-flashlight-dc-3~4.5v-530026
    I want to have kind of pulse mode instead of strobe to use with bike light. The matter is I don’t have time to understand programming these chips etc, just wanted to buld some bike lights. I can supply these boards and chips to you and pay for putting code onto them. Can you help?
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 97,539 other followers
