Dummy load uses gray code to adjust load in small steps
We’re not really interested in building a dummy load like this one for ourselves. But the concepts behind its design make for a nice little mental exercise as you read your way through the build description. [Pabr] wanted to build a dummy load which could be used to test a cheaply made gas generator. He wanted it to be as simple as possible, while providing a range of different loads. What he came up with is this¬†monotonically¬†adjustable load tester which uses gray codes for switching.
The video after the break does a good job of explaining the motivation for the design. Grey coding ensures that just one bit changes at a time. The example he uses to show the importance of this is when binary code transitions from 7 (0b0111) to 8 (0b1000). Three digits have been turned off and one has been turned on. Since he’s using light bulbs for his load this will turn off 700 Watts and then switch on 800W. That sudden jump in power draw can cause all kinds of problems with the generator’s engine. But the system he wired up will ensure that each flip of a switch moves in smaller steps.
10 thoughts on “Dummy load uses gray code to adjust load in small steps
    1. Good point… I had not realized that the resistivity of tungsten varies so much with temperature (e.g. according to this table).
      Fortunately I believe my wiring makes it possible to power the unused tubes from a wall outlet to keep them all hot. I will mention that in the next revision of the article (with credits).
      1. FWIW, Gray code is a God-send for debugging almost any problem involving multiple variables; it makes sure that every possible combination is considered only once, while only changing a single variable at a time. (Hint: order the variables, left to right, from least likely to be involved in the solution to most.)
        I remember having a complete nerdgasm when I first realized how much easier it could make problem solving. (I recall once some piece of equipment at a camp wasn’t working, so I grabbed a pad of paper and a pen and did up a 6 bit code to keep track of what they had tried and hadn’t. I lost track of how many times I had to remind them that they had already tried a particular combination.)
    2. I’m not sure if inrush current with halogen lamps is any greater than standard incandescent lamps of the same wattage. How a generator reacts to the inrush current phenomenon is one of the things being considered isn’t it? Pabr does mention using reactive components in testing in addition to loads that can be considered resistive for the most part.
  1. Clever solution.
    Not a very intuitive interface though. While [Pabr] appears to know the gray code sequence by heart, I think most folks (myself included) would need a cheat sheet affixed to the case.
    1. Yes, the space between the switches and the neon lamps was intended for a cheat sheet. But I use this simple trick to increment the value: Find the leftmost lamp that needs to change in the binary-coded word, and flip the corresponding Gray-coded switch.
      1. You and [Jason] have it exactly backwards. Read again, or watch the switch sequence as he increases the load; you’ll see the switch input is Gray code, which is converted to binary internally.
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
