BeagleBone powers this networked LED marquee
[Mahmut] calls this project SmartBox. It’s a BeagleBone controlled LED marquee which can pull down information off of the Internet.
The project started with the display itself. [Mahmut] used six 5×7 LED modules to populate a circuit board he produced himself. The low side of the modules is controlled by some MBI5026 constant current drivers, with PNP transistors on the high side. The display connects to the BeagleBone ARM board using a couple of IDC ribbon cable connectors. With that up and running he started working on the enclosure. The display board was modeled in Google SketchUp to ensure that the case design would fit it properly. The laser cut acrylic case is in two parts, the base holds the driver electronics, with a hinged section for adjusting the angle of the marquee.
So far there are a few different connectivity features which are shown off in the clip after the break. The BeagleBone has the ability to pull down Twitter feeds, notify about incoming email, and scroll messages.
Comments
  1. tehgringe says:
    I require ALL THE LINUX
  2. tehgringe says:
  3. wowme@wtf.com says:
    BOOTI !
  4. I’ve seen Mahmut doing this project. It is fun waiting to see what will appear on SmartBox screen. You can decide what hashtags you want to see from an online account. It has 3g connectivity or ethernet(directly to beaglebone) in demand. Cool project and useful one :)
    By the way, he is a cofounder of a hackerspace in İstanbul
    Base İstanbul
    baseistanbul.org
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
