Smashed Tablet In NES Case Lives Out Its Days As An Emulator
smashed-tablet-nes-emulator
The creator of this project started off with a 7″ tablet he received from a coworker. The screen was horribly smashed from one corner spreading out through the entire surface. But the hardware inside still worked, including the HDMI out port. He ended up transplanting the tablet hardware for use as an emulator.
After a bit of sizing up it was determined that the tablet hardware would fit inside the case of a broken NES. The battery would have been a tough fit, but this thing is always going to need to be connected to a television so there’s no need to work without mains power. The back plate was cut down to size and used as a try for mounting the motherboard in the case. Before that step he wired up a USB hub and mounted it so that two ports could be accessed through the original controller port openings.
There’s no details on the software used, but the final image in the gallery shows a game of Starfox being played.
[Thanks Cody]
25 thoughts on “Smashed Tablet In NES Case Lives Out Its Days As An Emulator
    1. And your point is??? Not everyone reads reddit, and may appreciate the info, regardless of where else it may appear on the web.
      So if you’ve seen it already, just move along… no need to comment.
      1. I’ve found it’s that way for lots of electronics. Not benefiting from economy of scale like the original manufacturers do seems to cancel out most of the savings you get by doing repairs. It’d prevent a lot of waste if this weren’t the case, but damned if I know how to fix it.
  1. As others have pointed out that is not a 7″ tablet. It is a very expensive and capable 11.6″ WIndows 7 tablet made by Samsung. Sorry to say but that is quite a waste considering how definitely repairable it could have been :-(
  2. I have to agree with what’s been said.
    Putting expensive PC guts into an NES case is more like a case mod, except this one looks like it could be refined a bit more to use the NES hardware better.
    Still an interesting start.
  3. Oh, wow, that hurts… The screen wasn’t even broken!!
    Next time send me the tablet, and I’ll send you a NES case with a raspi in it which would do the same job without wasting a heap of money…
        1. If anything it being windows makes the running of starfox even easier than if it was an android tablet. There are tonnes of console emulators on windows…..
          This is a samsung slate 7 tablet. Thats a full x86 based machine with windows 7 although I think its now available in a windows 8 version and being a normal x86 machine you can always install windows 8 yourself.
  4. Agree with most posts, this is a MASSIVE waste of high-ish end hardware. There is nothing wrong with that screen, would be worth a fair bit to someone with ability to repair it (likely most readers)
  5. i want to make this 2 but want to use a raspberrypi or android board to do this.
    android have a good nes emulator and its simple to do can use the orginele tv and powwer conector of the nes to hook up a new board
    1. Insult to injury!! Would have made more sense, like most people have said so far, to use a low-end android tablet. Like a COBY 7″ you can buy at most Raley’s stores for less than $100 USD.
Leave a Reply to asdhjkasCancel reply
