DIY A/V switch
I knew this was coming out, but [mike] was kind enough to remind me. [Ben Heckendorn]‘s latest How-To is up on engadget. He provides a method of building your own A/V switch with as many inputs as you want, cheap. Each input uses a $.50 bus switch – literally, you could build one with 20 inputs if you really wanted … Read the rest
