How-to Make A ‘usb Battery’
usb battery
found out yesterday that there’s a shuffle shortage and gadget battery life can only be expected to get worse.  bummer.  at least you can make the most of your waiting-for-shuffle blues and solder yourself a ‘usb battery’.  this little gizmo runs off a 9 volt battery and supplies your favorite little device with the proper 5 volts of mobile power.
in lieu of running an ipod off of it, i tested it with an mpx220 smartphone and it should work fine with any low power mobile device that can charge via usb cable.  read more for instructions on how to make your own.
here’s what you need to scrounge up:
  • 5.1v zener diode.
  • 100ohm or slightly greater resistor.  all i had was a 330ohm which works.  don’t try anything lower than 100ohm.
  • 9v battery connector and 9v battery.
  • flat female usb connector that mates with your device’s usb cable.  this is the hardest part to find.  i tore mine off an old usb extension cable.
wire it up
usb battery wiring
connect everything up as shown.  a board makes it easy, but in a pinch you could just wrap ends together.  the top two wires go to the battery and the bottom two are connected to the female half of the usb cable i butchered.  polarity matters on the diode, so check your work.
test it
usb battery voltage check
connect the battery and test the voltage over the diode.  it should be close to 5 volts.  if not, make sure you have everything wired correctly (pay special attention to the polarity of the diode).
try it
usb battery mpx220 test
still waiting for an ipod, i decided to grab my smartphone and kick the tires on the usb battery.  as you can see in the image, the device thinks it’s plugged in.  you should be able to use any low power device that charges via usb.
how it works
the zener diode conducts in the reverse direction when its breakdown voltage of 5.1 volts is reached, and the voltage across the diode will be that same 5.1 volts, so it acts to limit our 9 volt supply down to roughly 5 volts, which is what usb powers devices at.
the resistor is there to keep the circuit from shorting when the load (your shuffle) is removed.  if you use a resistor less than 100 ohms you’ll know it because it will get hot.  if you use too large a resistor, you won’t be able to supply enough current to your device.
finish the job
usb battery solder
as you can see, i’m pretty nasty at soldering.  i’m under strict orders from cl to keep this tiny and pocket sized for the ipod, so i’ve tried to cram everything as tight as possible.  as soon as minneapolis warms up enough for the ipods to migrate, i’ll be making a custom case for this.
till then, please send in your comments, ideas, and hacks.  i look forward to seeing what you come up with.
186 thoughts on “How-to Make A ‘usb Battery’
  1. I was Told it was dangerous to put a battery in a metal box..is this true? I was planning on using my altoids gum box for it… And which wire on the usb wires is the firewire?
  2. hi jason u dont know me but i saw your hack on hack a day.com and i was inspired by your usb charger so i decided to make my own. i used a usb-mouse adaptor and gutted it i then used a female power plug from sompthing(i cant rember what it was) and put it in i put all of your parts in the device and now i have a portable charger.my next goal is to get make a car atachment.thanks allot for the websight hack and an insperation. for some pictures or comments please email me at ngal@shaw.ca
  3. Buy a cheap 4-port USB adaptor and voila! four female USB sockets! I don’t know why I didn’t think of this (the battery adaptor). Thanks!
  4. I actually had plans for something much simpler… and that’s just taking usb ports off an old motherboard, and soldering the wires from the female 9 volt battery attachment to the positive and negative ends that went to the motherboard, so that the current would still flow through it, and 5 volts would still go out to the USB device as necessary to charge it. Just a thought, but this is sort of the discount version, not requiring any resistors, seeing that the USB ports should provide resistance on their own, right?
  5. well i tried this on a ipod 30g….it didnt charge…it said it was charging but it wasnt…no damage at all i did everything….no prob…ipod dose have an automatic shit of when the charge cable shorts….i was modding a car adapter for wall….diddnt know pinouts lol….but you can make a car adapter into a car/wall adapter…
  6. well i tried this on a ipod 30g….it didnt charge…it said it was charging but it wasnt…no damage at all i did everything….no prob…ipod dose have an automatic shut off when the charge cable shorts….i was modding a car adapter for wall….diddnt know pinouts lol….but you can make a car adapter into a car/wall adapter……i used a griffin car adapter instead
  7. We are importer & exporter dealers on all brand new models of mobile phones, ipods and
    playstation 3 at very cheap price with complete accessories. We are good / great in selling to
    bulks buyers and also individuals buyers.
    We have alots of items available for sale now, if you are interested in purchasing any one of
    them, kindly send to us an email with your enquiries to the company email address below :
    Contact Name : Hilton Bailey
    E-mail : tradearenaplaza007@gmail.com, tradearenaplaza002@ommail.com,tradearenaplaza007@yahoo.com
    Please visist our website for good enquiries: http://www.tradearenaplaza7.com
    Nokia N95………….$300us Dollars.
    Nokia N93i…………$250us Dollars.
    Nokia N93………….$230us Dollars.
    Nokia N92………….$200us Dollars.
    Nokia N91………….$170us Dollars.
    Nokia N90………….$150us Dollars.
    Nokia N80………….$140us Dollars.
    Nokia N71………….$165us Dollars.
    Nokia N70………….$120us Dollars.
    Nokia E90………….$290us Dollars.
    Nokia E61………….$200us Dollars.
    Nokia E60………….$150us Dollars.
    Nokia E61i…………$290us Dollars.
    Nokia Vertu………..$350us Dollars.
    Nokia 8800………. .$160us Dollars.
    Nokia 8800 Sirocco ( Gold )…..$250us Dollars.
    Playstation 3 80GB Europe version…$280us Dollars.
    Playstation 3 60GB Us version…….$200us Dollars.
    Playstation 3 Japan Version………$180us Dollars.
    Sony Ericsson W888i…$250us Dollars.
    Sony Ericsson W880i…$220us Dollars.
    Sony Ericsson W810i…$200us Dollars.
    Sony Ericsson W600i…$145us Dollars.
    Sony Ericsson w950i…$260us Dollars.
    Sony Ericsson w900i…$180us Dollars.
    Sony Ericsson w850i…$220us Dollars.
    Sony Ericsson W550I…$140us Dollars.
    sony Ericsson P950i…$210us Dollars.
    Sony Ericsson P800i…$200us Dollars.
    Sony Ericcson P990i…$180us Dollars.
    Sony Ericsson P900i…$160us Dollars.
    Sony Ericsson P800i…$170us Dollars.
    Sony Ericsson M600i…$280us Dollars.
    Sony Ericsson M608i…$300us Dollars.
    Motorola E36………….$120us Dollars.
    Motorola E398…………$140us Dollars.
    Motorola RAZR V3………$100us Dollars.
    Motorola V3x………….$130us Dollars
    Motorola V3i D&G………$150us Dollars.
    Motorola V3i………….$180us Dollars.
    Samsung D600………….$180us Dollars.
    Samsung D500………….$160us Dollars.
    Samsung E600………….$150us Dollars.
    Samsung E800………….$160us Dollars.
    Samsung P510………….$120us Dollars.
    T-Mobile sidekick 3……$150us Dollars.
    T-Mobile Sidekick 2 …..$110us Dollars.
    Treo 700w…………….$220us Dollars.
    Treo 650……………..$170us Dollars.
    Treo 700p…………….$230us Dollars.
    Apple IP-Phones 8GB……$300us Dollars.
    Apple IP-Phones 4GB……$230us Dollars.
    Xbox360 Platinum System..$200us Dollars.
    Xbox360 System Bundle….$170us Dollars.
    Xbox360 Core System Bundle$160us Dollars
    Xbox360 Core Bundle……$150us Dollars.
    Xbox360 Live Bundle……$160us Dollars.
    I-mate JASJAM…………$230us Dollars.
    I-mate JASJAR…………$200us Dollars.
    I-mate k-JAM………….$180us Dollars.
    I-mate JAQ4…………..$280us Dollars.
    I-mate JAQ3…………..$260us Dollars.
    I-mate PDAL…………..$240us Dollars.
    I-mate Ultimate 9150…..$380us Dollars.
    I-mate Ultimate 8150…..$360us Dollars.
    I-mate Ultimate 7150…..$340us Dollars.
    I-mate Ultimate 6150…..$290us Dollars.
    I-mate Ultimate 5150…..$250us Dollars.
    TOM TOM GO 500………..$150us Dollars.
    TOM TOM GO 510………..$200us Dollars.
    TOM TOM GO 700………..$220us Dollars.
    TOM TOM GO 910………..$280us Dollars.
    TOM TOM GO 300………..$190us Dollars.
    Blackberry 8300 curve….$350us Dollars.
    Blackberry 8800……….$200us Dollars.
    Blackberry 8700c………$200us Dollars.
    Blackberry 8700f………$230us Dollars.
    ETEN G500…………….$200USD
    Eten M500…………….$180USD
    ETEN M600…………….$200USD
    Apple Ipod video 30GB………………….$130us Dollars.
    Apple Ipod video 60GB………………….$190us Dollars.
    Apple Ipod Nano 4GB…………………….$90us Dollars.
    Apple Ipod Nano 2GB…………………….$75us Dollars.
    Apple 6 GB iPod Mini Silver M9801LL/A ……$50us Dollars.
    Apple 20 GB iPod M9282LL/A………………$35us Dollars.
    Apple 4 GB iPod Mini Pink M9435LL/A ……..$35us Dollars.
    Apple iPod 1GB Shuffle …………………$80us Dollars.
    We are importer & exporter dealers on all brand new models of television sets at very cheap price
    with complete accessories. We are good / great in selling to bulks buyers and also individuals
    buyers.
    Samsung HP-R4252 42 in Flat Panel Plasma TV……………..$450us Dollars.
    Samsung HL-R5667W 56 in Rear-Projection DLP TV…………..$500us Dollars.
    Samsung HL-R4266W 42 in Rear-Projection DLP TV…………..$400us Dollars.
    Samsung LN-R408D 40 in Flat Panel LCD TV………………..$400us Dollars.
    Samsung HL-R5067W 50 in Rear-Projection DLP TV…………..$450us Dollars.
    Samsung LN-R268W 26 in Flat Panel LCD TV………………..$300us Dollars.
    Samsung HL-R4667W 46 in Rear-Projection DLP TV…………..$400us Dollars.
    Samsung LN-R268W 26 in Flat Panel LCD TV………………..$350us Dollars.
    Samsung SlimFit TX-R3079WH 30 in Flat CRT TV…………….$350us Dollars.
    Samsung HL-R5688W 56 in Rear-Projection DLP TV…………..$550us Dollars.
    Samsung HLR5078W 50 in Rear-Projection DLP TV……………$500us Dollars.
    Sharp Aquos LC-32DA5U 32 in Flat Panel LCD TV……………$350us Dollars.
    Sharp Aquos LC-37D7U 37 in Flat Panel LCD TV…………….$400us Dollars.
    Sharp Aquos LC-26DA5U 26 in LCD TV……………………..$300us Dollars.
    Sharp Aquos LC-45GD7U 45 in Flat Panel LCD TV……………$450us Dollars.
    Sharp Aquos LC-20S4U 20 in Flat Panel LCD TV…………….$250us Dollars.
    Sharp Aquos LC45GD4U 45 in Flat Panel LCD TV…………….$350us Dollars.
    Sharp Aquos LC-45GX6U 45 in Flat Panel LCD TV……………$500us Dollars.
    Sony Grand WEGA KDFE42A10 42 in LCD Rear-Projection TV …..$400us Dollars.
    Sony Grand WEGA SXRD KDS-R60XBR1 60 in Rear-Projection LCoS TV.$600us Dollars.
    Sony Grand WEGA SXRD KDS-R50XBR1 50 in Rear-Projection LCoS TV.$450us Dollars.
    Sony Grand WEGA KDF-E55A20 55 in LCD Rear-Projection TV…..$500us Dollars.
    Sony Grand WEGA KDF-E60A20 60 in Rear-Projection LCD TV…..$600us Dollars.
    Sony Grand WEGA KDF-E55A20 55 in LCD Rear-Projection TV…..$550us Dollars.
    Sony Wega KLV-S32A10 32 in Flat Panel LCD TV…………….$300us Dollars.
    Sony Wega KDF-E50A10 50 in LCD Rear-Projection TV………..$450us Dollars.
    Sony Wega KDL-V40XBR1 40 in Flat Panel LCD TV……………$400us Dollars.
    Sony Wega KD-36FS130 36 in Flat Screen TV……………….$400us Dollars.
    Sony BRAVIA XBR KDL-V32XBR1 32 in Flat Panel LCD TV………$350us Dollars.
    Sony BRAVIA KLV-S26A10 26 in Flat Panel LCD TV…………..$300us Dollars.
    Panasonic TH-50PHD8UK 50 in Flat Panel Plasma TV…………$500us Dollars.
    Panasonic TH-42PWD8UK 42 in Flat Panel Plasma TV…………$350us Dollars.
    Pioneer PureVision PDP-5060HD 50 in Flat Panel Plasma TV….$500us Dollars.
    Panasonic TH-42PHD8UK 42 in Flat Panel Plasma TV…………$400us Dollars.
    Panasonic Onyx TH50PX500U 50 in Flat Panel Plasma TV……..$500us Dollars.
    Note : If you are interested in purchasing any particular item from us, kindly send to us an
    .com
    Thanks & God Bless.
  8. i was gonna take a 5v psp battery and solder wires going directly from that to the usb to charge my ipod and i was just wondering if that would work properly… any answers?
  9. Testing the Effectiveness of a Comprehensive Fatigue Management for the Police Police officers work some of the most demanding schedules known, which increases their risk of sleep deprivation and sleep disorders. The need to work frequent overnight shifts and long work weeks leads to acute and chronic partial sleep deprivation ….
  10. this is retarded. it will create 5 volts but with the give resistance it will only supply something around 20 ma, most 5 volt chargers start around 500 ma. even with a 100 0hm resistor its still only about 50 ma. this is a inefficient toy, go get a 7805.
  11. I was thinking about 4 rechargeble AA or AAA:
    4 times 1.2 = 4.8 volts. USB specs says: 4.5-5 volt is okay..
    No other components needed imho..
    I haven’t tried this myself, anyone wants to give it a go?
    About the 12/9volts zener or 7805: if you are looking for a very efficient batterypack, consider the Recom R-78B5.0-1.5 .. it doesn’t “burn” the extra voltages but transforms them efficiently to 5 volts.. not cheap, approx $20..
  12. Why not use a 7805 instead of the Zener ???
    7805’s are easy to find and they do not draw any significant current on idle… Keep the resistor as a current limiting device, but you shall be aware that a shunt Zener diode will draw a lots of current even when no device is plugged in the USB port.
  13. Greetings,
    Scrap the zener and simply run the current through enough common switching diodes to drop the voltage down from the source to the 5v level. You could hook a lantern battery to this in series with a common switching diode and be set. The voltage drop is usually 0.9 to 1.2 volts per diode and no current is lost across the zener or voltage regulator. Make sure your diodes can handle the forward current consumed by the device you’re charging.
  14. “the 7805 regulator will not give very good battery life since it starts to go out of regulation when the battery has dropped to only 7 volts. A better solution is to use a “Low Dropout Regulator” also known as an LDO. The LDO works with a lower voltage across it before it stops regulating. A popular example is an LM2940-CT-5.0. It is an LDO that fits into the same socket as a 7805 but has can still regulate with less than 1 volt across it. Now our 6 volt output from the 9 volt battery is enough to still get 5 volts.”
    http://www.bluebelldesign.com/Power1.htm
    LM2940 can be had for under $1 US (incl shipping) from eBay, or about $1.50 (plus shipping) from Mouser.
