HADA01 – Logo Cake
hadcakecolor2
We usually post stuff related to case mods rather than cake mods, but today is an exception. It’s our 01-th anniversary today and to celebrate we decided to bake a Hack-A-Day logo cake! The cake is a vanilla cake with vanilla frosting served on a homebrew circuit board platter. Celebrate our 01 Hack-A-Day style.
For this cake-mod you will need:
vanilla cake
frosting
various knives (spreading knife, box cutter, sharp kitchen knife)
chopstick or other square ended small clean tool
large green circuit board (like our motherboard isa bus extension card found on the street)
clear plastic from a zipper lock bag (to protect your cake eaters from solder lead and to protect your circuit board from cake and frosting)
black foam core board or similar
green lighting (super bright green led’s, green christmas lights, etc.)
First make a vanilla cake. Keep in mind this cake will be carved, so try to find a recipe that isn’t too crumbly. Our recipe is as follows:
Vanilla Cake Recipe (original here):
(this recipe is dairy-free and can be modded vegan, see original)
3 cups cake flour
2 1/2 tsp baking powder
1 tsp salt
2 eggs
1 1/4 cups water
1/2 cup vegetable oil
1 1/2 tsp vanilla
1 3/4 cups sugar
Preheat your oven to 350 degrees F (176 C). Mix together the dry ingredients in a large bowl. Beat the eggs in a medium bowl. Add to the eggs the oil, water, vanilla and sugar. Mix the wet mixture into the dry ingredients. Spray two cake tins with non-stick spray and pour in the batter. We used 1 round pie dish/cake tin and 1 rectangular cake tin to have shapes conducive to the Hack-A-Day logo. Bake the cakes for 40 minutes or until a knife comes out clean. Let the cake cool for a few minutes then transfer to a rack for cooling.
Prepare a vanilla or any white frosting for the cake.  This frosting should be spreadable but quite thick to make the logo as white as possible.
Vanilla Frosting
(also dairy free)
3 cups confectioners sugar (aka powdered sugar, or half regular sugar half cornstarch)
1/2 cup soy margarine (available at health food stores, we did not find this so we used hydrogenated coconut oil — in france called Vegetaline and melted it ahead of time in a saucepan)
1 tsp vanilla
3 Tbs rice milk (or soy milk or water, can use vanilla or plain rice/soy milk)
Mix the melted soy margarine into the sugar with a fork or food processor until smooth.  Add the vanilla and continue to mix.  Before adding the rice milk, chill the mixture for a few minutes in the fridge.  Add in the rice milk bit by bit until the consistency is just spreadable and smooth.  Place the frosting back in the fridge for five minutes.
Next while the frosting is cooling, make a serving platter. Find a large circuit board and some black foam core board. Trace the shape of your circuit board on the foam core board and cut an opening with a box cutter. Cut a piece of plastic from a heavy duty ziplock bag a few centimeters larger than the circuit. Wrap the plastic over the circuit board to protect the circuit and to keep the cake edible. Pop the circuit board in place in the cavity carved in the foam core board.
hadcake7
hadcake8
When the cake has sufficiently cooled, carve the hackaday skull out of the round cake using a sharp knife. The cavities for the eyes and nose were started with a sharp knife and molded with the square end of a chopstick.  The cake is carved upside down for a flat level surface.
hadcake12
Now cut four wrench-bones out of the rectangular cake:
hadcake13
Place the carved cake on the serving platter.
hadcake14
hadcake16
Remove the frosting from the fridge and remix it until smooth with a fork.  Spread the frosting evenly on the skull first.  Push the frosting down into the eyes and nose with a chopstick.  Stick the wrenches to the skull with a daub of frosting and finally frost the wrenches.
hadcake5
hadcake6
Place the hackcake in the fridge to further cool the frosting.
hadcake9
To serve your skull and wrench bones cake, place some bright green LED’s or green christmas lights around the edge of your platter.
hadcake10
hadcake11
Final step: serve your cake to some hungry hackers. Happy HADA01!
14 thoughts on “HADA01 – Logo Cake
  1. The other day I made brownies and thought to myself ” I should make the hackaday logo with frosting” But then i realized i was too lazy.
  2. Woot happy birthday! People complain about the hacks going south at times, and they do.. but even in the dry times, this is a site I have to hit daily. You guys rock!
  3. That French chick doesn’t know what she’s talking about. You’re supposed to BAKE a cake? That’s like BUILDING a GPS system instead of HACKING one. Here’s how you HACK a cake:
    ingredients:
    hackaday sticker
    tv-b-gone
    http://www.hackaday.com/entry/1234000340041425/
    small red pushbutton switch
    Altoids tin
    double sided foam tape
    wire
    LED mounting hardware
    clear label tape (optional)
    By the way, this is NOT intended to be a plug for tv-b-gone or Altoids. The idea is that you might have these (or other) items around your house. The whole idea of hacking is to make new junk out of old junk.
    directions:
    Remove the case from the tv-b-gone and remove the LED and the switch from the circuit board. Cover the hackaday sticker with clear label tape if you want (to keep the sticker design from becoming obliterated). Stick the hackaday sticker to the center of the top of the tin. Drill a hole in the nose of the hackaday skull, just big enough for the red pushbutton switch to fit through. Drill a hole in the middle of one side of the tin, just big enough for the LED/mounting hardware to fit through.
    Run wires from the appropriate places on the tv-b-gone circuit board to the tv-b-gone LED and the red pushbutton switch. The wires have to be long enough to mount the LED in the side of the tin, and to mount the switch in the top of the tin (you’re going to have to be able to open the tin, so the switch wires can’t be really short). Stick the tv-b-gone circuit board to the bottom of the tin with a piece of double sided foam tape. Mount the red pushbutton switch (the “candle”) in the hole in the nose. Mount the LED in the hole in the side of the tin, using the LED mounting hardware. Close the tin.
    One hackaday birthday cake!
    If you’re still hungry, try this cake:
    ingredients:
    small snack cake with flat top
    white icing
    food coloring
    directions:
    You want the top of the cake to be all white, so if it isn’t, remove everything down to (but not including) the cake dough. Spread the icing on the top of the cake. If the bottom of the cake is all white, forget about the previous steps and just flip the cake over. In either case, draw the hackaday logo with the food coloring.
    One edible hackaday birthday cake!
Leave a Reply to CaptSnufffyCancel reply
