[timmeh] already had a parallel port PCMCIA card when he started on this Playstation controller port card. He cracked the case to discover that the circuit board only took up about two-thirds of the case. After that it was pretty easy to fit the port onto the card and wire it up. The second slot in his laptop was non functioning from factory, so using the space wasn’t an actual loss.
