NES Controller Gets A Rumble Pak
Add some feedback to an original NES controller by making it vibrate. This feature is often known as Rumble Pak, a controller add-on for the Nintendo 64 which vibrated as a game feature. This version adds a small DC motor (in the upper right) with a screw soldered off-center to the motor shaft.
[Andy Goetz] and his friend built this as a robot controller, taking advantage of the latch and clock pins. Normally, nothing happens while both pins are held high, a signal that they easily patched into using an AND gate. This is actually a neat find, as the addition of an internal microcontroller could add bi-directional communication when the latch is high and the clock is strobed.
16 thoughts on “NES Controller Gets A Rumble Pak
  1. You KNOW it belongs on Hack-a-day when you see a quad-AND chip with its pins splayed flat, at an angle, and lead wires soldered straight to the pins!
    I assume they’re using the LED as a traditional diode in this case?
    Forrest M. Mims would be proud!
  2. Heck, I’m impressed with the screw soldered to the motor!
    The whole thing rocks.
    (Yeah I noticed the splayed legs on that IC too.)
    ‘sall good
  3. Just replace the cable to get an extra wire and use it to feed a serial->parallel shift register (or the aforementioned uC) hooked to the same latch/clock/Vcc lines. Ta-da! full-duplex serial comms.
    It’s how the “link” port in a Game Boy works.
    But this rumble thing is simple and effective, like all great hacks :D
  4. @xyz at first i skimmed the page on how it works, there’s no mention of how they get it to rumble from what’s happening in the game
    i read the page again and realized it’s not for playing a game at all but for controlling their robot
    it’s a deceptive thing to make a NES controller rumblepack hack and not even have it rumble when you’re playing an NES game
    maybe should have added ‘robot controller’ in the title
  5. I think the confusion is about what this is for – it appears this has little to do with NES games. This is a hack *only* for the controller. It will never “rumble” while playing a game. (correct me if I’m wrong.) It will only rumble when plugged into a DIY device which tells it to rumble. The hack was the fact that they got a rumbler to fit in the NES controller. To be honest, I don’t think there’s any game-related functionality to this yet. It’s totally hacker spirit though – dirty, haphazard, yet functional. Very cool.
  6. @Craig –
    Forrest Mims! Dude has a smoking hot daughter! Well, maybe not smoking hot, but she has done real science ON the topic of hot smoke…
    He’s the guy who launched a hundred thousand careers over 40 years. He’s big on Intelligent Design, btw.
Leave a Reply to FallenCancel reply
