Machining Replacement Parts With Hand Tools
Jeff is a huge music fan, and like many of us likes old technology, so it seemed a bit silly (to him) that he did not have a turn table. His dad had a spare in the basement. A neat old Braun model from the 1970’s that was broken.
Opening the unit up he found that part of the arm mechanism was broken, and thanks to the age of the turntable and the wonders of mass production chances of finding a replacement were slim to none. Not being discouraged he busted out the hand tools and fabricated the replacement out of some aluminum. The end result is a perfectly functioning turntable that will serve many more hours pushing out warm jams.
Check out the fourm post above to get details and pictures, and we just wanted to tell [Jeff], awesome job!
18 thoughts on “Machining Replacement Parts With Hand Tools
  1. Jeff, you the man! Not only have you fabricated a new part, but you have discovered one of the best ways to listen to music.
    Good on ya :)
  2. The old part was probably “pot metal” which was unfortunately used in a lot of vintage turntable mechanisms. Surprising to see it in a ’70s Braun though. That’s a handsome table you’ve brought back to life!
  3. I used to take old Sawzall blades and make firing pins for a gun I used to have. Good for around 1000 rounds each.
  4. It’s relieving to read that someone still uses a file and a saw while the rest of the world is too busy 3d-printing and laser cutting bathtub plugs.
  5. Been doing that for years too, not because I was in the Navy, but since I wasn’t born with a silver spoon in my mouth, my only alternative to fix something was not to buy a new one but fix it. And God knows how many time I had to turn/mill/sculpt metal/wood/plastic to reproduce a somewhat working part clone!
  6. nice work. this is why i love my dremel. infact, i resurfaced a dvd to near perfect condition with it the other day. unfortunatly the foil had been damaged as well, so my efforts were nearly in vein. but i learned its possible!
  7. Man this looks like shit, and to top it off this isn’t even a hack. Hell it might be a hack-job, but nothing more to make this a hack. Why is this on hackaday??
  8. Couldn’t resist but post…good work! i detest throwing stuff away, especially when it’s a nice as your turntable!
    @lou eney, he hacked the hell out of that alloy-now THAT’s hacking-fact.
  9. Thanks for the interest and support, guys. Next on the list will be restoring a tube preamp and power amp, and maybe some DIY speaker cabs after that.
    Mmm, tasty vintage audio.
  10. Making metal parts with hand tools (and simple powertools) is very satisfying. You should have polished it with Dremel though so it would look better!
  11. @Cricri
    Sounds like you were born with golden spoon in your mouth. I can afford most small parts but certainly not a mill or a lathe!
  12. @jpa
    You’re not wrong, but when I did it, it was a purely functional task and I wasn’t going for cosmetics; the part is all but invisible when installed. The pics I took were to show my dad (a tinkerer far beyond my talents) who gave me the turntable, rather than to immortalize the project for the HaD audience.
    I guess lesson learned for next time… ;)
    Jeff
  13. Bro, just order replacement part from machine shop in China for a couple of buks 
    Mind you, if you are making it for fun to try out your skills – I take my hat off. Most people our days would not know how to use a grinder, mind you making something that small and functional…. Well done!
Leave a Reply to Doktor JeepCancel reply
