Halloween Hacks: Terrifying Mask Follows You Everywhere
It’s less than 5 days away from Halloween and the projects to scare small children are pouring in. [Noel] sent in his robotic Halloween mask he’s been working on, and the only way his build could be any better is by placing it underneath a child’s bed.
[Noel] took the mask he used last year and stuffed a few styrofoam craft balls inside to ‘fill it up.’ Two LEDs and a PIR sensor were fitted into the eyes of the mask and a few more electronics added to the brain. A servo was fitted to the base of the project to turn the head left and right.
The build uses a Gizduino Arduino clone with an Adafruit Wave shield. After a little bit of wiring up the LEDs, PIR sensor and neck servo, [Noel] had a bit of coding ahead of him. He ran into a problem with the WaveHC and Servo libraries because they both used the same timer. After finding a another software-based servo libraries, he had a reasonably terrifying project to put in front of a bowl of candy.
Check out the video below for a demo of [Noel]’s work.
2 thoughts on “Halloween Hacks: Terrifying Mask Follows You Everywhere
Leave a Reply to austin Cancel reply
