Line-follower Is An Homage To [Homer]; Plans To Infringe Copyrights
The Chief Knock-a-Homer robot is [Psycho Freaky’s] shout out to The Simpsons. The robot design appeared in an episode where [Homer] built [Bart] a fighting robot. Since he’s not robot builder, [Homer] actually climbed inside the shell and dished out sweet vengeance while suffering some severe injuries at the same time.
But [Psycho] has the skills necessary to make this autonomous and keep it looking just like the TV show at the same time. He has a friend with a CNC mill, and used it to cut out case parts from Masonite which were assembled with hot glue. A pair of small servos drive two wheels at the rear of the base, with a ball-bearing universal wheel centered in the front. There are also two downward-pointing sensors which lend it the ability to follow a line as seen in the video after the break.
We love the paint job, it really polishes the look. But [Pyscho] isn’t quite done yet. He plans to add an audio circuit that will give the robot the ability to play back classic sound clips.
[Thanks Tim]
7 thoughts on “Line-follower Is An Homage To [Homer]; Plans To Infringe Copyrights
Leave a Reply to bzroom Cancel reply
