Last week we saw [Todd]’s solution to getting a tripod out-of-the-way when filming a few DIY videos. It’s an overhead camera gantry that allows him to move a camera around his garage workshop without a tripod getting in the way. This weekend, he’s back with a new and improved version. It’s a vast improvement over his Mk 1 gantry system, and it much simpler to build, to boot.
[Todd]’s new and improved overhead camera gantry builds is a vast improvement on his previous build. In the original build, [Todd] used only one cross piece between the overhead garage door tracks, and the carriage suspending the tripod overhead was extremely clunky.
Version 2 of [Todd]’s camera gantry again makes use of unused garage door tracks to suspend a tripod above his workshop. This time, though, he’s using two rails between these garage door tracks making pushing the tripod around his workshop much easier – even when not pushing it from the middle.
To move the camera across the workspace, [Todd] did away with the square tube between the garage door tracks and used another set of garage door tracks. It’s a beautiful system that moves very, very smoothly between his workbench and welding station, perfect for making a few high-quality DIY videos.
You can check out [Todd]’s build video after the break.
[youtube=http://www.youtube.com/watch?v=CZtF92BqP3s&w=580]
Too bad my workshop got no garage door :(
Like he said in the video, with the free rails and hardware you can get, you can put in your own rail system without even having the garage door.
You neighbors have a garage door….. You have screwdrivers and a hack saw….
Neighbor may have a shotgun :P
I like the visegrip stops at the end of the track.
