Every year, the ECE department of Carnigie Mellon University hosts Build18, an engineering festival intended to get students out of the classroom and into the workshop. [Andrew Toth] along with team members [Jenna MacCarley], [Peter McHale], and [Nicolas Mellis] have been busy this last week putting together an automatic bicycle transmission.
Most cyclists agree that a cadence of 80 RPM is just about right for most cycling. The team’s transmission uses Hall effect sensors to sense the cadence of the rider and will change to a higher gear if the cadence drops below 60 RPM and a lower gear if the cadence is above 100 RPM.
One of the requirements of the Build18 festival is the completed project must cost less than $250. By using an Arduino Mega and a servo to change gears, the team has a fairly low cost solution to automatically changing bicycle gears.
It’s a very cool project, and hopefully we’ll see a video once the competition is over at noon, EST today.
“The team’s transmission uses Hall effect sensors to sense the cadence of the rider and will change to a higher gear if the cadence drops below 60 RPM and a lower gear if the cadence is above 100 RPM.”
I think that should be the other way round…
This is what happens after pulling 3 consecutive all-nighters, and editing the wiki at midnight of the third night.
Why do they need an Arduino Mega? Wouldn’t an Uno suffice?
It’s just a convenient AVR development platform; *which* Arduino they used doesn’t really matter, if it were built into a final product they would surely make a custom board.
But when you change gears on a bike, you have to temporarily stop pedaling or pedal slower than neccessary. I wonder if it has a warning alarm for that. I don’t think I would like this on my bike at all.
It would probably be unpleasant to use, and cause extra wear and possibly damage to the chain since shifting and pedaling won’t be coordinated.
However, it looks like a fun project to build. Maybe the creator will decide it is not a practical way to operate the gears on a bike and take it off after a few days, but he will probably learn something in the process, and maybe some other fun project idea will come out of it.
I’ve seen this project before I think and I thought the same thing. Chain doesn’t mesh well with teeth when there’s no change in torque on the chain. I was thinking the best remedy for this would be to mechanically separate the rear wheel from the rear cassette with a fluid coupling of some kind. Not sure
When Jo says “But when you change gears on a bike, you have to temporarily stop pedaling or pedal slower than necessary.” [b]THIS IS NOT TRUE[/b]. The way a bikes rear and front derailleurs shift requires the chain to be moving at a decent speed to change gears in any direction.
Anyone who’s ridden a bike knows what he means. You can’t be applying torque while shifting, so you either stop “pedaling” or you “pedal slower than necessary” in the sense that you’re no longer putting energy into the drivetrain. It’s a pretty bad feeling when the chain starts shifting on it’s own while you are biking along. Again, most anyone who’s ridden enough bikes will at some point encounter the same thing when the derailleurs come out of adjustment.
If you have to change your pedaling when you shift, you were in the wrong gear to begin with. There should be almost no pressure on the pedals when you’re in the right gear and you can shift seamlessly, assuming you’re only going one gear up or down.
Of course, if you’re riding a Huffy, that might be a different story… all bets are off there.
As the people who ride bikes have pointed out, you need to easy up a little to relieve the tension on the chain before shifting.
The old advice has always been to stop pedalling for a brief fraction of a second, it’s easy enough to do when a pedal is at the bottom of a stroke.
Generally speaking it happens more when shifting to a lower gear (going uphill rather than down) as the chain tension will be higher.
If you have “almost no pressure on the pedals” then you’re probably not moving.
My first thought was to have a shift light similar to a car mounted on the handlebars somewhere. Or, if they really want to get ambitious, they could mount some sort of display to a helmet.
Eliminate the servos and just give the rider cues when to shift up or down.
This is a very cool idea!!!
Is the mega even needed? Just go with an ATMEGA328, 2 caps and a crystal – then add the servos. If the servos yank too much juice add some transistors and run it directly from the battery? Depending on the type of gear one could also play around with interfacing the transmission directly in the box.
Very nice project, i could use something like it myself on my foldable.
– agreed, seems like overkill, but probably what was available and easy to work with. -Could probably use an ATTiny and might even be able to cram it into a servo case, or a slightly extended one.
I have a feeling that using servos to drive a spring loaded mechanism is a very bad idea. They will constantly draw a high current and probably will have a short life. A self locking linear actuator would work better in this application.
A click shifter being driven by a servo would be a great way to handle this cheaply and without spending much power, with the side benefit that you could design the system with a detachable servo in order to operate it manually if the system failed.
You could actually hack the servos a bit: use some strong enough to prevent the springs from changing position even while unpowered. The the micro culould also use a transsitor to cut the power to the servos to save power.
Im offering this solution because servos big enough will probably be cheaper and easier to find compared to actuators…
There was hack while ago where author gave the spring away, solved :)
when I seen the blog entry title I was actually hoping it was a mechanical solution, putting electronics with nightmare durability isn’t too economical or practical…
I agree — an electronic solution on a bicycle seems very inelegant to me. Isn’t there a mechanical way to do this?
A gearless Continuously Variable Transmission would be interesting to try on a bicycle, but the losses would probably be too large to be practical.
Additional loses aren’t even noticeable. We tested the Nuvinci N360 and its efficiency was right around 95%. I’d argue the improvement in the rider’s efficiency by being in the perfect gear would outweigh any loss in the bike’s drivetrain efficiency.
You could remove the spring in the derailer, if servo positioned there would be no need for a ‘spring return’ to tension a cable that moves it.
Has anyone every tried to make a CVT system for a bicycle?
Wouldnt it be easier to use a CVT like a snowmobile? Zero electronics and 100% reliable.
http://en.wikipedia.org/wiki/NuVinci_Continuously_Variable_Transmission Is an example of a complex version.
Just buy one of these http://www.partsforscooters.com/CVT-Transmission and modify it. Far less than $200 and zero electronics.
The problem is efficiency. Humans make about a tenth of a horsepower sustained, and the the typical chain & derailleur system makes the most efficient use of that power. Belts aren’t terribly efficient (v-belts especially so), and even shaft drive isn’t quite as good.
Oh, I just clicked on your first link. That bicycle CVT is cool… it sounds like there are still some considerable losses, but it ought to be better than the belt type.
Actually, a reasonably fit person can put out roughly a quarter of a horsepower for 1-2 hours before getting tired.
Where do you find them these days?
Could be a mass production product when perfected, my dad used to race road bikes and it seems like it would be useful in road racing
Seems like racing would be the last place you’d want the system as envisioned. A racer needs to be able to shift gears in a heartbeat for higher or lower RPMs to suit race conditions – a system that was trying to maintain 80 RPM would work against that.
Fast electronic shifting could be great for racing, but I’m scratching my head a little as to why they’d pick a target RPM and actually make it an automatic transmission in that sense.
Re-inventing the wheel………
Nuvinci internal cvt bicycle hub.
Shimano DI2, an electronic shift system on the market currently which is sensitive enough to automatically trim the shifting and has cadence sensors, easily a software upgrade could make it all automatic. There are systems also for internal gear hubs with 7-8 gears coming. Plus these parts are race proven.
http://bike.shimano.com/publish/content/global_cycle/en/us/index/products/road/ultegra_di2.html
This won’t work very nice under strain when pedalling. The ideal solution would be imo a hub gear. actually there is one you can shift under strain: http://en.wikipedia.org/wiki/Rohloff_Speedhub
It is a bit expensive but it is a wonderful piece of mechanical work. I think it would be very ineresting to automate this speehub.
Seriously? Electronics? I would think this could easily be controlled by some type of centrifugal force mechanism.
Or even better, a centrifugal force mechanism that worked a CVT type of transmission arrangement… would probably be far less shock to the system and keep you pretty damn close to an ideal pace all the time, it would likely take less shock loading, though, so you might not be able to pull wheelies and whatnot.
Already designed and sold many years ago… It was called the “Landrider” on late night infomercials. Gear free bicycling for the mechanically declined.
Stop whining its a prototype people!
Admittedly, we could’ve been a lot more cool with the mechanical part, but all of us (on the team) are ECE (Electrical and Computer Engineering) majors, so while we had mechanical ideas, no one had the experience on how to design or manufacture it.
Also, while there are many other and arguably better ways to do this, we only had a week. On top of going to classes and such.
It’s always good to get a project up on its feet and out there for people to see, so you all should feel good about that.
At this point you might as well go whole-hog on the automatic shifting and just program it to shift as needed to wear the rider out as fast as possible. :)
I would not ride such a beast. Random shifts mean trouble! I commend the effort and the ingenuity, but not the product. Now, a continuously variable bike transmission would be pretty exciting, like the one made by that aussie with planetary gears.
There closest product out there is the Autobike Voyage http://evolvethebike.com/
It uses the Nuvinci CVT!
It’s still awesome experience and achievement for the students to put something like this together in a week. Nice Job!
As many posters have stated before, you have to remove torque from the pedals(pedal softer) while maintaining pedal speed.
Much the same way you let off the gas when upshifting in a car.
Why not just make the system a manualy-controlled automatic transmission?
As in the electronics are there to shift the gears but YOU control when the shifting happens by hitting one of two buttons on the handlebars.
An automatic transmission only works when it has control off, or can at least sense, torque being applied.
Wow – all this discussion on practicality. Dude – it’s a cool project. Way to go, good luck!
For everyone complaining “eww! electronics!” … The last several tour de france races were won with electronic shifting.
I have a mountain bike that shifts gears on its own. It typically happens when I am pedaling it really hard. The jarring to the knees is really extreme and damaging to them.
So a system that automatically shifts must somehow avoid that.
I much prefer concepts where I control the shifting, but it is done via servo. An auto option might be cool.
Why would anyone want to put something on a bicycle that has almost no durability? Efficiency means nothing if it breaks within a year…
To all people including myself who want mechanical auto for the durability: http://www.bunchobikes.com/auto.htm
Companies have been doing those hubs for a long time, seems you could make it work with a lot of gears like 18 or 21…
seems if a light-spring centrifugal force clutch would also work, you just couldn’t get high RPM…
Cool project guys! That’s quite a feat for a semester project, let alone doing it in a week!
Here’s a video of an automatic shifting bike a few of us have been working on over the last couple of years: http://www.youtube.com/watch?v=38GudmnyZKo
http://www.youtube.com/watch?v=cd2-vsTzd9E
cleaner.
That IVT video is from 2008. Is it commercially available yet?
The youtube video link is up:
http://youtu.be/KFmDDD-pwwc
Cool video guys. Have you tried tightening up the shift band? How are you handling coasting (ie rider not pedaling)? You could have the system ignore any pedal rpm’s below a low rate like 5 rpm.
Why would you use a hall effect sensor that requires power when a centrifugal clutch makes more sense?
Because it’s not 1960 anymore.
New transmission CVT design by BitRaptor. Is a continuously variable transmission CVT gear only (the only one functional in the world), very compact and lightweight, and which could replace the current systems both for efficiency, simplicity and not least the costs.
Because this CVT work only with pinions is better the all other systems by efficiency and high torque transmission.
In the web page you will find more explanations, drawings and a short video of a basic prototype.
http://www.bitraptor.com/en_edyson_CVT.html
http://www.bitraptor.com/en_andeguro_bike.html
The first prototype will be ready for tests during this year.
Other possible applications CVT design by BitRaptor are: bicycles, motorcycles, cars, automobils, boats, gearboxes, electric motors, steam and wind turbine, as well as a large number of industrial or agriculture applications whenever is necessary some adjustment of the gear ratio.
Very nice bike!
I’m just curious if it is possible for a student to design an automatic gear transmission in bicycle which shifts gear in both front and rear derailleur?
