Okay now this is seriously awesome. [Rodger Cleye] has made a real working Hoverboard.
You guys might remember the recent [Tony Hawk] and [Christopher Lloyd] viral Hoverboard hoax video… Well, this isn’t that. Nope, not even close. It’s real.
The Hoverboard is a quadrotor on steroids — it features four 1200W brushless motors driving 12″ props, a massive 13.4Ah 5S Li-Po battery, and a [Marty McFly] mannequin wearing the classic red vest. He’s counter-balanced [Marty] and the battery around the rotors which makes for a surprisingly smooth flight. It even has a run-time of over 5 minutes, thanks to a whopping 83% efficiency using the 12″ props.
[Rodger] designed and simulated the entire system in eCalc before construction — He had first attempted a bi-copter design, but opted for the tried and true quad-rotor instead. The frame is made of 1/2″ PVC pipe to conserve the mass budget, but altogether it still weighs an unbelievable 20lbs! How close are we to being able to give toddlers the ability to fly?
Just take a look at the following video — we’re seriously impressed.
This has gotta be one of the biggest home-made quads we’ve seen so far. Mind you the Spruce Goose of quadrotors is still a bit bigger…
You may want to mute the audio, unless if you like listening to the equivalent of a few thousand angry bees
thats a surprisingly accurate description
The sound of the video ruined my listening of Earl Hooker !
And you (presumably a “hacker” of some sort) couldn’t figure out how to remedy that?
Sounds, more like the doppler effect when watching nascar … or even a flanger effect from an audio editor.
Haha, I liked the sound of the angry bees. Had a bit of a rough landing at the end lol.
The past few years has seen some crazy new entries in the ‘spruce goose of multirotors’ hall of fame. The HobbyKing beer lift is a good place to start: http://www.youtube.com/watch?v=UVwt7oWC5fc
You might think that’s almost big enough to sit on… well:
http://www.youtube.com/watch?v=L75ESD9PBOw
I forgot about this!!!
Hi – UAV propulsion specialist here. I’m very much doubting that his whole drive system efficiency is >80%. Not without some very very special aerodynamics work and exceptional motors. I’m not just buying it with what look like APC props. It’s a nice piece of work, but it’s not what’s claimed (no matter what eCalc says).
ecalc has a + or – 20% fudge factor in it.
Flying Cuisinart ! Notice absence of any blade guards. NOT smart.
I seriously doubt it was ever meant to carry a living person so blade guards aren’t really needed.
It’s not meant to ram anyone either, but eeh…
Im reminded of the “famous last words” text floating on the net in the 90s :-)
What is this shit? Doesn’t even carry a real human. Better make a post about the new martin fan backpack.
I can do that too, use an old fucked up rubber love doll and strap it on top of a large quadcopter. Maybe fill it with hydrogen to make it lighter and to blow it up for special effect.
Maybe I would even earn some money if I use it to make advertising flights for the local whorehouse .
That sounds…awesome lol. Do it.
Only 640W is needed to hover, each motor or the total of all four motors combined?
Looks pretty nice. I imagine it going to get much, much louder to lift a real person. The weight of that rig + person is going to easily be 10x the one shown, unless the rider is a child or a jockey.
Two observations / questions..
How much does inflatable ‘Marty’ weigh?
This could be fun for real mortals – by making a prone driving position (as in a luge)… The center of gravity will be much lower for improved balance, and offer an amazing personal flight experience !
i hope marty doesn’t fall into one of the props…
I would add a distance detecting IR device on the bottom to control altitude, and some minimum speed to control how fast it lowers from a altitude that is higher then some set amount.
And I would power it using Transformer coil to coil power transfer from an under the road, some coil system. with capacitors that wind down speed for soft landing on power failure.
So, do it.
Real human girl on 2 RC hellicopter
https://www.youtube.com/watch?v=77uK19KxMuI
