Clever Re-purposing Of A Power Drill Results In A Mini Wood Lathe
Power Drill Wood Lathe
Ever use a lathe? No? Neither had [Jack Hauweling], but that didn’t stop him from building his own and learning how!
Lathes are a lot of fun, especially for small wood working projects. Using mostly wood and a few small pieces of hardware, [Jack] was able to build one in an afternoon that works quite well!
He’s using a cheap corded power drill to drive the work piece, but what we really like is how he made the spur center and spur live center out of a few pieces of threaded rod and a standoff. It’s a simple system that lets him secure the work piece fairly easily simply by tightening the threaded shaft of the live center.
In the video after the break he goes through the entire build process and even shows off his first attempts at using the lathe — he actually was able to make a very nice tool grip on his third try!
Too much work? Well, you could always print it… Personally we prefer this giant treadle powered wood lathe though, if your going to go to that much effort.
[Thanks Jeremy!]
25 thoughts on “Clever Re-purposing Of A Power Drill Results In A Mini Wood Lathe
    1. Nah, all wood lathes do that. A bit of a grease in the hole is a good idea (if you could be bothered).
      You can get centers that have bearings (rolling centers) but they’re mainly for metal lathes, and usually only found one wood ones if you have excess cash (and like to show off). (Ok, they’re becoming more common as they’re pretty cheap these days.)
      1. Definitely not all wood lathes! Most modern wood lathes (including mine) come with a live (rotating) center for the tail stock. But its safe to say the first several thousand years worth of wood lathes were all equipped with dead centers, and they work well enough.
          1. Well.. more became common decades ago.
            For a treadle lathe or a pole lathe a dead centre is essentially just a point to stick in the wood. They donlt revolve the wood very fast. But outside demonstrations and heavy duty traditionalists. It’s gonna have a motor attached.
            For anything with a motor, which can be used to spin wood a few thousand RPM, a live centre is needed to stop the wood burning.
            Price.. £20 up to silly money for models with heavy duty bearings and interchangeable points.
      2. A live center is one with a bearing. A dead center is one like in the video that is stationary. And even the $120 harbor freight wood lathe comes with a live center, so the idea that it’s some showy accessory is ridiculous. They aren’t becoming common, dead centers are ancient history.
      1. Well, in a way I did. This is the older lathe I took apart, which I also built out of scrap structural steel
        http://i.imgur.com/P8y0bCS.jpg
        So I did, but probably not how you thought I did. I needed the machinery I’d made that head out of on my first build as a dedicated grinder, that prompted the rebuild. No, for real, I made the whole machine, twice in fact.
    1. It’ll probably be ok. They have good air flow for cooling. I’ve got a cheapo black and decker I bought when I was a kid that I now use for full time wire brush use and it hasnt died yet. If not, they’re cheap to replace.
    2. A very long time assuming the drill is of reasonable quality. The reason: all but the worst crap have an integrated fan – even the simplest type of fan will produce good air flow to the motor. A plastic impeller on the motor axis is almost free too.
      BTW I use a drill modified for better stability as a poor mans metal lathe. Works great with brass, steel and copper at least. The most obvious limit except the obvious precision problems is the chuck size, it’s almost impossible to find a replacement chuck that can take pieces larger than 13mm.
      1. Hand drills typically use universal brush type motors. Universal style motors just seem more delicate to me than induction motors. Although I suppose I’ve seen both types fail by about the same frequency.
  1. I sometimes think about making one, but then I realize I have no idea why I’d need it and what to sue it for.
    I like the video though, it’s always interesting to see how people rig things up.
      1. There’s the catch. Until you have some idea what you’d use a lathe for they are useless items. For producing some kinds of work lathes are the best machines for the tasks though. Think round. If you want to make something that is round a lathe is likely your best bet. Well, perhaps cylindrical?
        I need to take the time to make myself some more file handles on my lathe. I’ve one I made and it is like my favorite handle.
        1. The thing is that the cylindrical things I use are already cylindrical, pipes and rods and tubes and such. But sometimes you do need a groove around it that is straight and not wobbly though. So in rare cases I could use one for a few seconds.
Leave a Reply to PeteCancel reply
