Nowadays, you can get into ham radio on the cheap. A handheld radio can be had for less than $30, and licensing is cheap or free depending on where you live. However, like most hobbies, you tend to invest in better kit over time.
[Günther] just finished up building this portable ham station to meet his own requirements. It runs off 230 VAC, or a backup 12 V car battery for emergency purposes. The Yaesu FT897d transceiver can communicate on HF + 6m, 2m, and 70 cm bands.
This transceiver can be controlled using a
With the parts chosen, [Günther] picked up a standard 5 U 19″ rack, which is typically used for audio gear. This case has the advantage of being durable, portable, and makes it easy to add shelves and drawers. With an automotive fuse block for power distribution and some power supplies, the portable rig is a fully self-contained HAM station.
