Wrapping Up The Last Midwest RepRap Festival
The Midwest RepRap Festival is over – forever. This was the last one. Apparently enough people complained that Goshen, Indiana wasn’t in the midwest. The number of Dairy Queens I passed contradicts this, but whatever. Next year, there’s going to be a different con in Goshen. Same content, different name. If you have a suggestion, you know where to put it.
I promised the world’s largest 3D printed trash can, and I gave you the world’s largest 3D printed trash can. This gigantic orange vase was printed on the PartDaddy, SeeMeCNC’s 18-foot tall delta printer a few months ago at the NYC Maker Faire. I have been using this as a trash can in my basement since then, making me one of the only people who have their trash can on Wikipedia.
DSC_0019
A failed print on Saturday morning
Speaking of the PartDaddy, this is what a fail looks like. The first PartDaddy print was a Groot, a 13-hour long print job. It was left running overnight, but it ran out of PLA pellets sometime around 4 in the morning. If you’re wondering what the black band is around the Groot’s face is, here’s the breakdown:
The PartDaddy sucks PLA pellets up from a trash can (that’s not 3D printed), and dispenses it into a hopper above the print head. This hopper was 3D printed on the PartDaddy, and there is still a little bit of colarant dust in there. When the PLA pellets run out, that dust is embedded in the extrusion. When you realize that masterbatch is only about 5% of the finished plastic, it doesn’t take much black dust to discolor a print.
Yes, this is a print fail that could have been fixed by having an all-night bash. A few other people left their printers running overnight including [The Great Fredini] and his Scan-A-Rama. This was a Rostock Max that had something wonky happen with the Bowden. There was filament everywhere.
How about some Star Wars droids? An R2 from the Droid Builder’s Club was there, but there was also the beginnings of a completely 3D printed Roger. While we’re on the subject of plastic robots that will fall apart at a moment’s notice, there was a K’NEX 3D printer. Yes, it’s made almost entirely out of K’NEX, and it did work at one time. Those orange parts sitting next to it? Those came out of the K’NEX printer.  If you’re looking for the definitive RepStrap, there ‘ya go.
NEW FILAMENTS
For the last few months, metal filaments – PLA with tiny particles of copper, brass, bronze, iron, or aluminum have been available. MRRF was the first place where you could see them all together. A few things of note: these filaments are heavy – the printed objects actually feel like they’re made out of metal. They’re actually metal, too: the iron-based filaments had a tiny bit of red corrosion, and the Lincoln death mask above was treated with acetic acid. These filaments are also expensive, around $100 for 1kg. Still, if you want to print something that will be around in 100 years, this is what you should get.
The most beautiful printer ever
MRRF should have had a contest for the best looking 3D printer at the show. A beautiful delta from Detroit Rock City would have won:
DSC_0076
DSC_0075That white hexagon in the center is a ceramic PCB that I’m told cost an ungodly amount of money. Underneath the ceramic build plate, there’s a few Peltiers between the bed and the large copper heat sink. The heat sink is connected to the three risers by heat pipes, making the entire printer one gigantic heat sink. Why would anyone make such an amazing art deco printer? For this.
Because you can use Peltiers to heat and cool a bed, a little bit of GCode at the end of a print will cool the bed to below room temperature. If you do your design right, this means the print will just fall over when it’s done. When the print bed is cooling, you can actually hear the bond between the bed and print cracking. It’s beautiful, it’s cool, and I’m told this printer will make its way to hackaday.io soon.
There you go, the best and coolest from the last Midwest RepRap Festival ever. There will never be another one. It only needs a better name, and [John] at SeeMeCNC is great at coming up with names. Just ask what VIP is a backronym of.
I told you there would be a T-shirt cannon. That’s 300 PSI shop air.
11 thoughts on “Wrapping Up The Last Midwest RepRap Festival
    1. As a resident of the Pacific Northwest, it has always appeared to me that Indiana and surrounding States are actually Mideast. Midwest are Montana, Wyoming, Nevada, Colorado and New Mexico. They are in the middle of the western Half of the USA. Texas and the column stacked to its north are the Middle States. All the ones between them and the Eastern Seaboard States are the Mideast States.
      The erroneous application of “midwest” to the States that have been Mideast since California joined the Union in 1850 springs from the era when the Mississippi River was the western border of the USA and all between it and the States on the coast was “the west”, putting everything between the land bordering the river and the costal States into “midwest”.
      As the nation expanded across the Big Muddy towards the Pacific, the southern half of the “old country” came to be called the geographically correct Southeast while people kept stubbornly incorrectly calling the Upper Mideast States “midwest” and continue to do so, while also calling everything between the Mississippi and the Pacific the overly broad “The West”.
      Correcting our geographic naming conventions to match actual locality is as likely as getting people to stop calling the traditional Iroquois male hairstyle a “Mohawk” * or tartan patterned fabrics “plaid”. A plaid is a Tartan pattern blanket worn as part of traditional Scottish military gear.
      * Which is all because of one old movie from 1949, “Drums along the Mohawk”, where the costumers chose the more dramatic Iroquois style over the actual Mohawk practice of plucking all the scalp save for a small square patch on the back of the head, gathered into three decorated braids. Want to prove how badass you are? Get a *real* Mohawk, plucked traditional style. Shaving is for wimps.
  1. Drive thru on defaulted privatized toll road (Major Moves) suburbs and corn.
    South Bend-Studebaker, Fort Wayne-Packard. The later had a major team, the Pistons till they moved to where they still make cars.
    We have a Subaru plant in Lafayette.
    Flyover is right, we have had for years the greatest density of flights overhead anywhere in the US maybe the world.
    No mountains.
  2. Funny thing happening here: I’m in South Korea and none of Havakaday’s images are showing. Just not loading? Anything to do with blocked servers from your side?
  3. Thought about the peltier thing a couple of times, this has sold it to me. But think I’ll go alu-peltier-alu-glass and hope the glass doesn’t crack!
    Though the extra weight over the PCB-mirror setup I have now will be unwelcome on my moving bed machine.
Leave a Reply to Liam JacksonCancel reply
