Electronic Ruler Works Out Logic Truth Tables
Like [Brad], we’ve seen a number of PCB rulers out there. [Brad] was looking to take the idea and run with it. His DigiRule is a ruler with a logic gate simulator. What he built is a mash-up between PCB rulers, and the concept of electronic business cards.
All told it simulates seven logic gates, four flip-flops, and includes a four-bit counter. On one end of the ruler a CR1220 battery feeds the 18F43K20 which is performing the logic operations using buttons and LEDs. Of course the truth tables are printed on the back silk-screen, but playing with the lights is a lot more fun. We do find it fairly amusing that the centimeters on the bottom of the ruler are notated in binary.
It makes a lot more sense to hand out rulers than business cards; people might actually use them after you leave and you can still include contact info. This form-factor also breaks the mold. You can have a lot more space on a ruler and you’re not constrained by thickness (although [Limpkin] solved that problem). While we’re on the topic of business cards [ch00f’s] USB etch-a-sketch style card and this logic-based information delivery device top our favorites list.
[via Dangerous Prototypes]
23 thoughts on “Electronic Ruler Works Out Logic Truth Tables
  1. Looks really good. It would be great for beginners / students.
    The only thing that I would *try* to do differently would be to recess the the cell into the board and use a CR2016 or LIR2016 and perhaps a USB plug printed on the board for recharging.
    1. I don’t think you will have the ruler on often enough to really warrant a charging system. The recessed thing would have been neat though.
    1. Subject to errors/tolerances from manufacturing the PCB or damage from normal use. The way it is designed is the best method.
  2. Use the linear optical sensor from a flat bed scanner. Let it find lines on your paper and give the read out of how many pixels away they are from each other.
  3. Hilarious the SI units are measured in binary since it is fundamentally a decimal system. Conventional Measure, OTOH is often binary or at least partially so. (1/2, 1/4, /18, 1/16…) (cups, pints, quarts, gallons, etc.)
    1. When he sets the flip flop to JK mode and both J and K as ‘1’ (equivalent to toggle) the toggle only occurs once per button press so there must be some de-bounce somewhere. Perhaps he is scanning the button slow enough that bounce isn’t an issue.
Leave a Reply to RÖBCancel reply
