Creepy Van Parked Down The Street Is A Nomadic Sauna
Sometimes you need a good sweat and if you’re like [JoeCMorgan] you can’t be bothered travelling to a sauna, it needs to come to you. He took care of that problem by building the SaunaVan.
Many moons ago, SaunaVan started life as a Vauxhall Combo van. At some point it was abbreviated from a Van to a trailer. You can’t tell from the picture above but this van no longer has a cab up front. Like many trailers, it eventually became a storage unit, which is how [Joe] found it. He cleaned out the old tires, tents, and detritus, and started planning out a mobile sauna. The van’s interior was already stripped, so the first order of business was to cut a hole in the front wall of the van. The hole became a steel “nose” which housed the chimney. All this allowed [Joe] to place his 1920’s Husqvarna stove as far forward as possible.
The van’s gas tank was cleaned out and became a water reservoir, complete with a pump that is safe to use with water. A shower placed outside allows for a quick cool down after a hot sauna. The biggest job was building the interior. [Joe] measured out the wheel wells and cut panels to form the interior walls of the van. Some fiberglass insulatisauna2on between the wood and the outside wall ensured the van would stay nice and toasty. [Joe] put in some pre-finished flooring and added benches to cover the wheel wells. The benches hide storage for wood, and the wiring for the van’s sound system. Speaking of which, your sweaty friends won’t be happy without some tunes so [Joe] added speakers and a radio. Check out the video after the break to see it all in action. This thing is just begging to be parked next to the Carpool DeVille.
One thing [Joe] didn’t mention was a fresh air intake, which is vital on a setup like this. We’d also add a carbon monoxide detector just to be sure combustion gasses don’t build up inside the van’s body.
The first firing of the antique stove was a complete success. The newly christened SaunaVan’s temperature got up over 90°C (194°F)! That might sound hot to some, but it’s not far outside the norm for a sauna. The low humidity helps keep things comfortable, but we wouldn’t recommend staying inside for more than a few minutes.
22 thoughts on “Creepy Van Parked Down The Street Is A Nomadic Sauna
  1. Those speaker cones won’t hold long against the humidity.
    >”The low humidity helps keep things comfortable,”
    A proper sauna is not a dry place. See that bucket in the corner? That’s for throwing water on the stove to get it full of steam.
    1. And there’s no rocks on the stove (pronounced ‘kiuas’) on which one throws water. This is not a sauna, this is just an old van with a stove.
      1. You don’t technically need the stones. They just increase the surface area and heated mass to make more steam at once. Without the stones, the water pools up on top of the stove and slowly boils off. Sometimes regular sauna stoves have little stone cups or stones with holes drilled in them that trap water and do exactly that.
        Not having the stones is probably for the best, because the van is so cramped that people could get burns otherwise.
  2. A couple of guys I know built a sauna in a construction trailer. It was as spacious as a normal sauna with the mobility of a caravan. One time they took it out on a lake and sawed a hole to jump into. I think the wheels sized up after a few years and it fell into disrepair.
  3. This seems more like a Sous-vide device with the addition of a little smoky seasoning.
    Well done, but potentially creepy.
  4. Nice. I remember watching a documentary about saunas and its rituals in Sweden, where they showed a sauna in the back of a bus, that could be used while driving around… And a group of girls using that sauna ;-)
  5. Looking for Ascension Patient Portal then check here Official Ascension Patient Portal with step by step guide including a screenshot. All the information about Ascension Patient Portal is only for how to access the official portal using this guide.
