Now You’re Printing With Water
How do you earn a place in a flower festival with a handful of Arduinos and a 3D printer? By building a water curtain that draws flowers. That’s exactly what Tecnoateneu Vilablareix, a hacking community in Spain did. They built this project specifically for Temps de Flors, a popular annual gathering in Girona, Spain. More than just a flower festival, the event opens gardens and courtyards of culturally importance to the general public that are closed the rest of the year.
A pile of nozzle fail.
The water curtain uses four Arduino Nanos to control the valves, which work in pairs to draw flowers, words, and patterns. A Mega provides a wifi connection  to receive commands. Over 16 continuous days worth of print time went into the 128 valves and 64 nozzles that make up the water curtain. It took the group around 24 iterations to get the valve design just right—they have to be able to shut off quickly.
There’s an eight-video playlist after the break and a special video that shows how much we love pandering. Most of the ones in the playlist are quite short and demonstrate the final version of the water curtain. Others show the valve testing. The last is a time-lapse of the group setting it up at the festival. If you’re in the area, the festival runs until May 15th.
Now that you’re in the mood for computer-controlled water shows, here is a fountain controlled with a RaspPi.
18 thoughts on “Now You’re Printing With Water
Leave a Reply to SpirosPCancel reply
