This is just good, clean fun. Well, maybe not clean since this souped-up racing Roomba appears to move too fast to actually clean anything anymore. But did they ever really clean very well in the first place?
[Roland Saekow] doesn’t offer much in the way of build details, but the starting point was a 10-year old Roomba Discovery. The stock motors were replaced with 600RPM planetary drive motors and a whopping 12A motor controller. The whole thing is powered off the standard Roomba 14.4V battery pack, but we suspect not for long. Those motors have got to suck down the juice pretty fast to be able to pop wheelies and pull hole shots like it does in the video below.
No word either on how it’s being controlled; our guess is RC, since it looks like the collision sensor grazes a chair leg slightly around the 0:33 mark, but doesn’t seem to change direction. It’d be cool if it could operate autonomously, though. We wonder how it would deal with the Virtual Walls at those speeds.
File this one under “Just for Fun” and maybe think about the possibilities for your defunct Roomba. If speed-vacuuming isn’t your thing, there are plenty of other Roomba hacks around here.
I love these hacks. I call them “because you can” hacks and they’re what engineers do in the free spirit of their own time.
MOAR POWER!!!
I love this! :D
turned a poor vacuum to a fun racing car
So it’s an RC car with a Roomba shell?
Lol that’s awesome
It looks like a horseshoe crab on speed, I bet it could cover your whole house in s#it in no time!
So am I the only one that instantly thought about modified roomba racing? Underground robot vacuum racing would be pretty awesome.
I could see racer roomba support vehicles for FPV racing quadcopters – to retrieve them after you crash.
Sounds like the introduction of an futuristic sci-fi.
The wheelies have more to do with the terrible suspension setup of a Roomba than they do with the power it has. The wheels in those things are spring loaded to extend, and are retracted by the weight of the unit. This makes sure that a wheel will hit the ground when it goes over the threshold between rooms or over the edge of a carpet. It doesn’t take much to make them tip a bit, they do it slightly when stock, and the iRobot Create units we use for Botball tournaments will do it if you command it to 100% speed from a stop.
This does tip more than a stock configuration, but it would probably handle better with the wheels locked down.
Hello Dan, I am really impressed with this car and now I am thinking to buy it for my kid. Could you please tell me from where I could buy this. No doubt, you have done a great work again.
Best Regards,
Peter
Tim the tool man would approve!
