Vintage Tube Radio Restorations
[J.B. Langston] has some vintage late-40’s/early-50’s tube radios that he wanted to repair – a Motorola All-American 5 AM radio, an Air Castle AM/FM radio and a Sears Silvertone AM/FM radio. He goes over, one by one, the three vintage radios, the problems they had, and how he got them back into working order. No finding a replacement microchip here, this was all about replacing capacitors and finding vacuum tubes!
In contrast to most modern builds we see on Hackaday, vintage radios are fairly simple – mainly turret-board builds with a transformer, resistors, capacitors, coil and tubes. The main issues in any vintage electronic repair is checking the capacitors because old wax paper and electrolytic capacitors can degrade and will need replacing. When repairing the All-American 5, [J.B. Langston] had an issue with the transformer, and he goes over how he fixed what’s called silver mica disease in it. While many parts were replaced with modern equivalents, only a selenium solid-state rectifier in one of them was replaced by a different part – a silicon diode and a high-wattage series resistor.
Looking at the inside of some of these radios, it’s surprising that they could be restored at all – 65-odd years of rust, dust, dirt and grime will take their toll – but [J.B. Langston] was able to fix all three radios and clean their Bakelite cases so they look and work like new. He goes over what he discovered, how he fixed the problems and the links to where he got help when needed. We’ve seen some great vintage radio projects over the years, including adding RDS (Radio Data Systems) to a vintage radio, converting a vintage radio with modern technology and even some other radio restoration projects.
22 thoughts on “Vintage Tube Radio Restorations
    1. There’s a lot of places to order new old stock tubes, like tubedepot.com and tubesandmore.com. Several Russian companies still make new tubes as well. And yes, the voltages are dangerous. That’s why you should always use an isolation transformer, especially for the radios without a transformer of their own.
  1. Some useful tips there. I hadn’t heard about that silver migration problem before, so thanks for that.
    The common tubes like the ones in an All-American 5-type radio seem fairly easy to get. I find that coils and chokes are usually the hardest to find, but fortunately they don’t often fail. The open-frame tuning capacitors are getting harder to find too.
    There’s a big RCA multiband tombstone radio in our livingroom that’s been patiently waiting for a rebuild… maybe this post is the kick I need to tackle it.
  2. A common issue not mentioned in the article is when carbon resistors go out of spec high from age. This is more of an issue with old test equipment than it is with radios, but it’s still worth it to check all of the resistors when restoring an old radio.
    1. I did mention that in the Motorola article. I had a 22 ohm resistor that was more than 3x higher than it should have been that prevented the radio from playing at first. I ended up replacing all the resistors in that radio even though it probably wasn’t completely necessary. One thing that must be mentioned is that you need to remove at least one end of the resistor before testing it. Otherwise the multimeter will measure the path of least resistance, which may not be directly across the resistor you’re trying to measure.
  3. I’m looking for a cathedral or tombstone type radio that can’t be repaired so that I can give the wooden case new life in a project that has been living in the back of my mind for several years.
  4. Amazing coincidence. I just started fixing a Philco tube radio with Loctal tubes, about 1945. vintage. There is a funny problem though. There are two shafts coming out from the chassis (pot. and var. cap.) and yet there are 3 holes in the radio case front for the shafts. Chassis and case fit perfectly though. It looks like someone swapped the case from a very similar Philco model :)
  5. That is beautiful.
    The only thing left to do is to make his own mini AM radio station to play some real oldies. Hearing today’s music come out of that radio…. aaarrrggghhhh.
    Off my lawn, etc.
      1. There are many simple RF signal generators that can do AM modulation. The Eico model 324 is a common vacuum tube generator of similar vintage to those radios which would do the trick. There’s a more modern solid state design that has been rebadged by BK Precision, Parts Express, Lodestar, and probably several other brands, available new for under $200. Just connect an audio source, set the RF frequency to an unused spot on the dial, and connect a wire to the output. It will be low power, but if you run the wire within a foot or two of the receiver’s antenna, you should get something that will work. Warning: none of these generators are exactly high quality — they’ll drift in frequency, and their output will have quite a bit of harmonic content. But they can still be useful for the purpose.
          1. “Practical Transmitter” may be stretching it a bit. The range will be very limited. But if you run a wire from the signal generator very close to your radio’s antenna, that old Heathkit generator should work. If it turns out to be too weak, you could probably wrap a wire around the receiver’s ferrite bar antenna a few turns, to increase the coupling. But that probably won’t be necessary.
            If you search the web for “old time radio” you can find some nice sources of audio programming that would make a good demonstration for your older radios.
  6. Learn a little first aid for finishes and construction. Cleanly glue flat loose surface wood layers. Decades ago I gave an Atwater Kent floor model to a friend. Very little was bad a tube or two, the cabinet shabby from shed storage. He stripped all of the loose walnut finish layer off! Then he varnished the ruff ugly core layer and called it done.
Leave a Reply to Richard ÖhlingCancel reply
