There was a time when just about every ham had a pricey VHF or UHF transceiver in their vehicle or on their belt. It was great to talk to friends while driving. You could even make phone calls from anywhere thanks to automatic phone patches. In 1980 cell phones were uncommon, so making a call from your car was sure to get attention.
Today, ham radio gear isn’t as pricey thanks to a flood of imports from companies like Baofeng, Jingtong, and Anytone. While a handheld transceiver is more of an impulse buy, you don’t hear as much chat and phone calls, thanks to the widespread adoption of cell phones. Maybe that’s why [Bastian] had bought a cheap Baofeng radio but never used it.
He was working on a traffic light project and wanted to send an RF signal when the light changes. He realized the Baofeng radio was cheap and cheerful solution. He only needed a way to have the PC generate an audio signal to feed the radio. His answer was to design a UDP packet to audio flow graph in GNU Radio. GNU Radio then feeds the Baofeng. The radio’s built-in VOX function handles transmit switching. You can see a video demonstration, below.
What we didn’t see is how he plans to demodulate the signal on the receiving end. Of course, you could do that with GNU Radio as well. You could also repurpose some ham packet radio software should you want more network-like connectivity. Don’t forget you need to be sure you have the right licenses in your locality for your desired frequency band. These radios will often transmit on a wide range of frequencies, so be careful.
This is a good example of how you can use GNU radio for more than just SDR. We’ve seen it used to generate test patterns, for example. If you want to try your hand at GNU Radio, we talked about how to get started with no special hardware.
Here is the talk he had about the topic at this year’s FOSDEM: https://fosdem.org/2017/schedule/event/trafficlights/
This is cool! I’ve been working on a similar idea to generate a morse code audio signal to feed into my radio.
rant
That said, can I just say that while I dislike jargon in general, Amateur Radio jargon is the *worst*? “Handy talkie” is one of my least favorites. =P
/rant
Jargon? I don’t know what you mean!
Just last night, I was having a ragchew with an XYL from ZL-land on 20m CW. WX at her QTH is FB, she says, and I was impressed with her 599 signal from a QRP rig. We signed off with hearty 73’s and 88’s, A great QSO!
Wasn’t that perfectly clear?
i do amateur radio and hate all of that. Why cant we just speak english. I am sure lots of hams also bitch about “text jargon” and emoji too then go and transmit this garbage
Some of that originates from the days when Morse code was heavily used.
People just started using the same abbreviations in other modes where they were less necessary.
You realize not everybody in the world has english as it’s native language, right? So abbreviations, Q code, the phonetical alphabet, etc, really help to understand other people.
For me it is :)
But really, ham radio is a hobby that explicitly requires knowledge. Those Q codes are the least of it :)
“Handie Talkie” was/is a Motorola trademark for their line of handhelds.
No need to reinvent the wheel. https://www.its.dot.gov/index.htm
Look at Connected Vehicle, Vehicle to Infrastructure (V2I), Vehicle to Vehicle (V2V), and Vehicle to Pedestrian (V2P). Somewhere in there are links to the communication standards. Frequencies, packet formats, etc.
