A hackspace discussion of voltage regulators within our earshot touched on the famous μA723, then moved on to its competitors. Kits-of-parts for linear regulators were ten-a-penny in the 1970s, it seems. A rambling tale ensued, involving a Lambda power supply with a blown-up chip, and ended up with a Google search for the unit in question. What it turned up was a hack from 2014 that somehow Hackaday missed at the time, the replication by [Eric Schlaepfer] of an out-of-production regulator chip using surface-mount semiconductors when his Lambda PSU expired.
Lambda were one of those annoying electronics companies with a habit of applying their own part numbers to commonly available chips in an effort to preserve their spares sales. Thus the FBT-031 in this Lambda PSU was in fact a Motorola MC1466, a dirt-cheap common part in the 1970s. Unfortunately though unlike the 723 the MC1466 has long passed out of production, and is rarer than the proverbial hen’s tooth.
Happily, these chips from the early 1970s were often surprisingly simple inside. The MC1466 schematic can be found on its data sheet, and is straightforward enough to replicate with surface-mount discrete components. He thus created a PCB that replicated the original pin layout even though it overlapped the original footprint. A few parts were slightly unusual, dual transistor arrays and a matched triple diode, but the result proved to be a perfect replacement for a real MC1466. Of course a project like this is almost too simple for [Eric], who went on to build the incredible Monster 6502.
If the data sheet lacks a schematic, never fear. You can always try reverse engineering the chip directly.
Straight from the Oilfield in the middle of Sahara I replicated some 741 opamps using subminiature tubes from the Soviet Union in order to build a canbus transveiver for an arduino to talk to a diesel engine ECU. No other components available until next transport arrives… who knows when.
Pics or it didn’t happen!
He has to finish making a ccd from desert sand before he can take a picture.
HAHAA
I feel your pain dear college!
From an Oilfield Electronic Engineer to another… How much down time you got…or much down time you were able to save? :)
Crafty. Awesome article and references also. Interesting studying and reading into where some had encouraged me to go if I decided to leave the pharma industry (chip manufacturing, i.e. solar and silicon in general). Maybe they saw my James Franklin Hyde periodic table in my office and that inspired them also.
The MC1466 is rare? Well, looks like I’m about to flood the market with some NOS units.
Or just wait until I’m the only one with them.
Please…. Can you sell me two? I would be so grateful.
I also just made an obsolete IC from discretes. Here’s the hackaday.io link: https://hackaday.io/project/29179-disintegrated-lm3909-15v-led-flasher
Here is the Motorola MC1466L / MC1566L Data Sheet
http://chemelec.com/Projects/MC1466/MC1466L.pdf
http://chemelec.com/Projects/MC1466/MC1466.htm
This is the only link that actually still works
