Anodizing Aluminium In The Land Of The Queen
Aluminium is a useful material, both for its light weight and resistance to corrosion. This resistance can be improved further with various treatments, one of the more popular being anodizing. This is the process behind the fancy colored metal bling on your cousin’s BMX bike. It’s possible to perform this in the home lab, when taking the appropriate precautions.
[The Recreational Machinist] has been experimenting with anodizing on and off for the last few years, and decided to share their process – as a “what did”, rather than a “how to”. The video is from the perspective of performing this task in the United Kingdom, as the availability of chemicals varies around the world and can affect the viability of various processes involved.
All the relevant techniques are covered, from cathode design to the hardware chosen to give the best results. There’s even discussion of the use of magnetic stirrers to prevent bubble marks, as well as proper cleaning processes to avoid unsightly blemishes from fingerprints or other contaminants. Perhaps the most useful tip provided is that using specific anodizing dyes does give the best results, though it is possible to get by with various types of clothing dye. As always, your mileage may vary.
There’s a big difference between reading theory and seeing the specifics of an actual working process, and [The Recreational Machinist] does a great job of showing off the realities of achieving this at home. We’ve seen it done before, with different chemicals too. Video after the break.
11 thoughts on “Anodizing Aluminium In The Land Of The Queen
    1. Yes, the ancient battle of Dimondium versus Dimondinium.
      “It’s possible to perform this in the home lab, when taking the appropriate precautions.” I bet it works with or without the appropriate precautions.
  1. I suppose you use what you have available. I’ve done my anodizing with a TIG welder as the power supply and titanium strips to support the piece. Cranking the current up too high makes for a kinda nasty finished surface, but sometimes that doesn’t matter. I have never had success with powdered fabric dyes so I’ve always just left a clear anodizing. The results with proper metal dyes look so good that I’ll have to look into getting the real stuff.
    Are you allowed to buy car batteries in England? The appropriate anodizing acid concentration is similar to a very discharged battery…
Leave a Reply to [grounded]Cancel reply
