Like the tastes of the makers that build them, LED cubes come in all shapes and sizes. From the simplest 3x3x3 microcontroller test, to fancier bespoke installations, they’re a great way to learn a bunch of useful embedded techniques and show off at the same time. [kbob] has done exactly that in spades, with a glittering cube build of his own and published a repository with all the files.
Just like a horde of orcs from Mordor, [kbob]’s cube is all about strength in numbers. Measuring 136 mm on each side, it’s constructed out of 64 x 64 P2 panels, packing 4096 LEDs per side, or 24,576 total. A Raspberry Pi is used to run the show, allowing a variety of animations to be run. Unfortunately, it lacks the raw horsepower to run this many LEDs at a decent frame rate. Instead, it’s teamed up with an ICEBreaker FPGA, which can churn out the required HUB75 signals for the panels without breaking a sweat.
Thanks to the high density of tiny LEDs, and the smooth framerate of the animations, the final effect is rather gorgeous. [kbob] notes that there’s actually a lot of people working on similar projects with ICEBreaker muscle; a recent video from [Piotr] is particularly impressive.
The LED cube will likely remain a staple for sometime, and we can’t wait to see what comes out next from the community. You can even throw in some OpenGL if you wanna get fancy. Video after the break.
ICEBreaker LEDCube. #cutecube It is quite an attractor of attention. I am glad so many of you like it. Thank you @kernlbob @tnt @GeorgeIoak @vifino @zzaurak and many others for inspiration and hard work to make it a reality. :) pic.twitter.com/2ZIiwj5L1v
— Piotr Esden-Tempski esden@chaos.social (@esden) August 10, 2019
Damn, that is gorgeous !
Anyone know where to get 6 square OLED panels? ;D
What about earth?
https://web.archive.org/web/20180808061041/http://www.progonos.com/furuti/MapProj/Normal/ProjPoly/Foldout/Cube/cube.html
If someone knows how to scale the models for 3d printing the cube assembly on the github page by 1.25x could you please share?
Can you not just set the scale in your slicer to 125%?
Why is the obvious things never obvious at the time haha!
Thanks.
Wow,! What a design ! It would be cool to hang it by one corner from the ceiling. Reminiscent of
a computer in a Star Trek (TOG) episode. Just so a beautiful woman doesn’t appear and say…..”I am for you (insert name here)….”
