While [Selim Olcer] was relatively happy with his Kenwood TM-D710a radio, he didn’t like the fact that it needed a bulky external GPS “backpack” for APRS location data. So he decided to crack open the head unit and see if he couldn’t integrate his own GPS hardware (machine translation). Not only did he succeed, but he even threw in Bluetooth compatibility for good measure.
With the repair manual circuit diagrams in hand, it was no problem to find the GPS RX and TX lines that were being broken out to the external connector. Unfortunately, the radio’s electronics are all 5 volts and the GPS module [Selim] wanted to use was only 3.3 V. So he came up with a small PCB that included not only the voltage regulator to power the GPS module, but also some voltage-dividers to level shift those signals.
Since the Kenwood TM-D710a was already designed to accept a GPS upgrade module, he just needed to change some configuration options in the radio’s menus for it to see the new hardware. Technically the project was done at this point, but since there was still room in the case and he had a GPS module spitting out NMEA sentences, [Selim] tacked on a common Bluetooth serial module so he could see the position information on his smartphone. With an application like APRSdroid, he now has a nice moving map display using the position pulled from the radio’s GPS.
With this modification done it looks like the head unit is ready to go, but that’s only the beginning for a mobile rig. Now we want to see how he integrates the whole thing into the car.
same here in german: http://www.ov-d20.de/tm-d710_gps.htm (without bluetooth)
Bluetooth in handheld and mobile ham radios is an idea whose time is long past due. Imagine traveling cross-country and having your VHF/UHF radio talking to an app on your smartphone and constantly updating the radio’s repeater list to those nearby. That’d let the high-end makers of such radios beat those cheap radios from China.
See the Kenwood TH-D74. Already built in. Also in the Yaesu FT3D.
73
http://www.xente.mundo-r.com/eb1dpb/pagina/modificacion%20tmd710.html
