Head Lamp Gives Glowing Creature Comforts
What can we say? It’s 2021, and we could probably all use a psychotic glow worm lamp in our lives about now to lighten the mood and/or provide a new focal point for sitting and staring. Tired of dragging out that creepy little Elf on the Shelf every holiday season? [LiabilityLabs]’ Head Lamp is slightly less terrifying and far more functional. Really, the options are limitless.
The brain of this scare snake is an Electromage Pixelblaze LED controller, a powerful Wi-Fi enabled little board with a live web editor. [LiabilityLabs] recycled 20 milky plastic containers and their lids to help diffuse the light and avoid hot spots by holding the LED strip in the center of the tube. There’s a momentary button on the glowy guy’s tail that lets [LiabilityLabs] cycle through different color patterns with ease.
Whether you need a mascot for your stream channel, a confidant, or a refreshing rainbow rubber ducky of problem solving, Head Lamp is flexible. Feast your eyes on some brief animations after the break.
Want the glowies without the willies? This mesmerizing fiber optic lamp is an easy build.
5 thoughts on “Head Lamp Gives Glowing Creature Comforts
  1. The first thing I thought of was the song “Carpet Crawlers” by Genesis from the Lamb Lies on Broadway album. This is a bit creepy…
  2. Mount the tail end with the tube collapsed in a chemical drum with a blower fan to make them rise up out of the drum and wave around when you switch them on.
  3. Great idea to add the creepy dolls head to the end. Made it transition from home decoration into nightmare in an instant.
