Yee Haw: Full Set Of Cowboy Emojis Now Available
This cat looks like he plays bassoon in a jazz band.
Emojis are all well and good if you want to add a fun tiny picture to your textual communication to try and add some finer context or zing, but what if the appropriate tiny picture doesn’t accurately represent you or how you feel? Never fear, cowboys, the emoji set you’ve been dreaming of has now been created.
The set was initially created by the appropriately-named [pensivecowboy], by using scripts to place cowboy hats atop existing emojis from the twemoji set automatically. Over time, it was decided to instead just apply these hats to the 300 most-used emojis instead, with some manual fettling in cases where the script-generated result needed a little work.
The fire is coming out of the hat, which is just absolutely fantastic attention to detail.
The result is a complete set of Unicode-compatible cowboy and pensive_cowboy emojis, for when you’re feeling like a cowboy, or feeling like a sad cowboy. Scripts are included for those wishing to work more intimately with the emojis, and there’s even Discord channels to give instant access to the new emojis for those with Nitro subscriptions.
Is this important, groundbreaking work? Your opinion on that likely depends on how much of a cow or a boy you are. But down at the ranch, it’ll likely bring many a smile to a pensive cowboy’s face. A quick search did note the absence of a :snake_in_my_boot: emoji, however, which could be a safety issue down the line.
We’d love to see some open tools built for programmatically hacking emojis; if you’ve developed some, drop us a line. Alternatively, consider this emoji gun that shoots small foam emojis at other people to delight or annoy them.
8 thoughts on “Yee Haw: Full Set Of Cowboy Emojis Now Available
Leave a Reply to Feinfinger (still totaly uncaffeinated)Cancel reply
