The Benefits Of Critiquing Your Own PCB Designs
In a recent retrospective video, [Phil] from Phil’s Lab goes through a number of his early PCB designs, to critique and comment on what he likes and doesn’t like in these designs. Even though it’s only been a few a few years, he founds plenty that’s wrong. From poor and inconsistent formatting in the schematic, to sloppy and outright broken PCB layouts. It’s a fascinating look at years of lessons learned.
[Phil] comments on the importance of clear labeling and organization of sections and pages in the schematic to make it obvious what the function of a block is. Other lessons include the labeling of nets to make PCB routing a lot easier, making good use of PCB planes, getting all relevant information on components and layout in the schematic as a comment, and connecting decoupling capacitors to their relevant pins.
Although we tend to forget about older projects, it can be very interesting to take a look at them now and then, to see (hopefully) our progress over the years. In the case of [Phil] it’s fascinating to see the transition from a basic two-sided board with THT components to multi-layer boards with STM32 MCUs.
8 thoughts on “The Benefits Of Critiquing Your Own PCB Designs
  1. Impressive progression of skill in a short time.
    My own #1 lesson learned: Add test points. Or more generally: Design for test.
    And a hint: If test points are made with large vias, then use an extra dummy board, install pogo pins in those vias, and these exactly match the board under test. Easy bed ‘o nails.
    1. Schematics or logic diagrams have to flow or the boards will likely end up looking like the schematic, a hodgepodge of
      of disassociated parts wherever they fit. Boards have rules, material, size, power/ground planes, I/O locations, skylineing with other components etc.
        1. Okay- This is genius! I’ve always just been careful to keep test points on a grid and use protoboard (through hole test points are far superior. how the hell am i supposed to hold my probes on a flat pad?), but this is so much more flexible- and, like the other guy said, a good use for those excess boards. defo stealing :)
Leave a Reply to PaulCancel reply
