Hydrofoils Love This One Simple Trick
the active foil flying across the water
Earlier in the year, [rctestflight] created an active hydrofoil RC craft but found the actual performance very lacking. Luckily for him and for us, he continued to tweak it and one tweak suddenly turned it from a nightmare to a dream.
That tweak was adding ArduPilot’s airplane model. The design had three servos, which each actuated the angle of a foil underneath one of the three pontoons. The ship propelled itself via some propellers mounted near the top. If you know much about ArduPilot, you notice that active hydrofoil boat doesn’t show up on the list of supported platforms, and you’re right. [rctestflight] points out that the three servos actually function as a plane underwater. The front two are ailerons and the back one is an elevator, all things that ArduPilot knows how to handle with a tightly controlled loop except for one thing; there’s no altitude data.
So he stole a trick he developed earlier for his ground effect plane and used a distance sensor to let ArduPilot know how to adjust things. He used a sonar sensor instead of lidar as it works better with water and he was pleasantly surprised when he took it out on the lake and it just worked wonderfully. The original goal with the active stabilization was to have the efoil immune to choppy waters, and we’re sad to say that it didn’t quite reach that lofty target. The single sonar sensor follows the wave in front of it beautifully but can’t handle the complex waves being thrown at it. Perhaps some sort of sensor fusion algorithm could provide the necessary data to be truly resilient. But we love watching the foil glide across the water and it is hard to remember that it’s actively flying rather than just floating that way.
Others have tried and failed to 3D print a hydrofoil while others have succeeded. We love that [rctestflight] came back to finish the fight and came away a champion. Video after the break.
9 thoughts on “Hydrofoils Love This One Simple Trick
  1. I think to overcome some of the issues he could use a real time filter wit look ahead prediction. This is done for low level automated supersonic flight on jet fighters. Perhaps some type of Kalman filter would work.
    1. The problem is to figure out the average height of the water surface, when it’s got all sorts of waves superimposed.
      Captain Obvious would simply take a running average that’s bound to be long enough to include at least a couple periods of the waves.
      Problem is, this depends on the speed and direction of the vessel and the period of the waves. Good news is that when the boat is moving faster, and thus needs a tighter control loop, the waves are also moving along faster underneath, so you can shorten up the averaging window. Bad news is that this is probably nowhere near as easy as I’m saying it will be…
      This is a fun/cool problem.
      But whatever solution, the hydrofoil legs have to be longer than the waves are high, or there’s no hope.
      1. Maybe the solution is not with digital readings but mechanical. Foiling dhingies have had the problem of checking height of foiling for a while and the most common solution is a magic wand, which is a mechanism to closeloop actuate the foil angle based on the height of flight. You can see how this works in this video.
        Just as an inspiration source but it might be worth a try.
        https://www.google.com/search?q=moth+magic+wand&oq=moth+magic+wand&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQABjvBTIKCAIQABiABBiiBDIKCAMQABiABBiiBDIKCAQQABiABBiiBDIHCAUQABjvBdIBCDMwMTNqMGo0qAIAsAIB&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:1580c6d8,vid:CK5_nMYdmgE,st:0
Leave a Reply to evaprototypeCancel reply
