Remoticon 2021 // Arsenijs Tears Apart Your Laptop
Hackaday’s own [Arsenijs Picugins] has been rather busy hacking old laptops apart and learning what can and cannot be easily reused, and presents for the 2021 Hackaday Remoticon, a heavily meme-loaded presentation with some very practical advice.
Full HD, IPS LCD display with touch support, reused with the help of a dedicated driver board
What parts inside a dead laptop are worth keeping? Aside from removable items like RAM stick and hard drives, the most obvious first target is the LCD panel. These are surprisingly easy to use, with driver boards available on the usual marketplaces, so long as you make sure to check the exact model number of your panel is supported.
Many components inside laptops are actually USB devices, things like touch screen controllers, webcams and the like are usually separate modules, which simply take power and USB. This makes sense, since laptops already have a fair amount of external USB connectivity, why not use it internally too? Other items are a bit trickier: trackpads seem to be either PS/2 or I2C and need a bit more hardware support. Digital microphones mostly talk I2S, which means some microcontroller coding.
Some items need a little more care, however, so maybe avoid older Dell batteries, with their ‘spicy pillow’ tendencies. As [Arsenijs] says, take them when they are ripe for the picking, but not too ripe. Batteries need a little care and feeding, make sure you’ve got some cell protection, if you pull raw cells! Charging electronics are always on the motherboard, so that’s something you’ll need to arrange yourself if you take a battery module, but it isn’t difficult, so long as you can find your way around SMBus protocol.
These batteries are too ripe. Leave them alone.
Older laptops were much more modular and some even designed for upgrade or modification, and this miniaturization-driven trend of shrinking everything — where a laptop now needs to be thin enough to shave with — is causing some manufacturers to move in a much more proprietary direction regarding hardware design.
This progression conflicts with our concerns of privacy, repairability and waste elimination, resulting in closed boxes filled with unrepairable, non-reusable black boxes. We think it’s time to take back some of the hardware, so three cheers to those taking upon themselves the task to reverse engineer and publish reusability information, and long may it be possible to continue.
9 thoughts on “Remoticon 2021 // Arsenijs Tears Apart Your Laptop
  1. We had lots of laptop device prototypes at my last employer and we’d swap out the batteries once they (inevitably) pillowed up. The joke was that we finally made a curved display laptop.
    1. That’s what happened to my Surface Pro 4. Curved screen and pillow batteries. Still held a charge though. Took the opportunity to upgrade the flickering display and the SSD. Now has 2TB of Samsung goodness as I type this reply on it.
    1. Bad advice on diodes. I had one USB hub + media reader that did that. Yes past tense. The chip tolerated it when it was further down stream at 4.8V, but it died when I plug it directly to my PC.
      Diodes are unreliable way of providing a voltage drops just because of large variation – part to part, voltage drop vs current, temperature etc. The voltage drops goes much lower when your device goes into power saving!
      USB voltage also has a large allowable range – some even goes a bit higher to compensate for drops.
      A LDO is about $0.10 to may be $1 depending on where you bought them. Don’t cheap out and make these kind of hacks.
  2. I took a touch pad out of a laptop. With 4 wires it looked worth a try. A few minutes later and a multimeter I figured out what’s what and now have a small USB touch surface set in walnut that sits on a 88 note keyboard behind the keys. It’s better at changing presets and knobs in a soft synth where the qwerty and mouse ways don’t play well live on a crowded stage or studio.
    1. I pulled a couple of touchpads out of laptops, and yes, only a few pins. I can’t remember if they were PS/2 or USB. I never got around to mounting one for use.
      Sadly, I don’t see much electronic junk much anymore.
  3. ‘spicy pillow’ Hahaha, I like this. Well, not exploding batteries, but the term. I’ll have to remember it for the next time I open old hardware and find a spicy pillow of my own.
Leave a Reply to JehuCancel reply
