The Prints Don’t Stop With This Prusa I3 MK3 Mod
One of the issues with 3D printing is that when a print is done, you need to go back and pull the print off the bed to reset it for the next one. What if you needed to print 600 little parts for whatever reason? Most people might say get lots of printers and queue them up. Not [Pierre Trappe], as he decided that his Prusa i3 MK3S+ would print continuously.
The setup was dubbed Loop and consisted of a few parts. First, there’s an arm that sweeps the build plate to clear the printed pieces, a slide for the pieces to descend on, and a stand for the printer to sit on that puts it at an angle. The next step is to modify OctoPrint to allow a continuous print queue. The slicer needs to change as [Pierre] provides some G-code to reset the printer and clear the print.
We were especially impressed with the attention to detail in the documentation for this one. There’s extensive guidance on getting the bed adhesion just right, as you can’t have it come off mid-print, but you need it to detach cleanly and easily when the arm sweeps across the bed. Calibrating that first layer is essential, and he provides handy instructions to dial it in. Additionally, temperature and material play a crucial role, and [Pierre] documented the different materials and temperatures he used while developing Loop.
While continuous belt printers are arguably the “correct” answer to the question of printing 600 little parts, they come with their own baggage. Being able to pull off something similar on a printer as reliable and well supported as the Prusa i3 makes for a compelling alternative.
21 thoughts on “The Prints Don’t Stop With This Prusa I3 MK3 Mod
  1. Could make the world’s slowest random dice roller. Print a set, knock them loose. Read the numbers. Toss printed dice into a grinder to be re-extruded into filament.
    1. Wild guess…the fact that you have “Please ask for schematics and source code; the mechanical design should be visible from the video” in the description whereas this project has a GitHub repo will all of the information up front probably has something to do with it getting “lost” when you sent it in.
      1. RW’s 1st law of online content, the signal to noise ratio of a video is 1% until proven otherwise.
        RW’s 2nd law of online content, if a blog post starts off reading like ad copy, the signal to noise ratio is 1% until proven otherwise.
  2. This is directly stolen from a trademarked system developed by 3DQue. At first the guy behind loop still provided credit to where it was due but as this system got traction he’s miraculously forgotten to credit the team that is rightfully responsible for this design. Pathetic.
    1. I have no intentions on stealing IP. If you would inform yourself better, you would know that all used sources are declared on my GitHub page of this project since the first full publish.
      This mod is a gift from me to the community from which I’ve learned a lot.
      As stated on the GitHub page, I got some inspiration from 3D Que but all parts are made from scratch. A small portion of my motivation was to build a better system as I was not satisfied with knocking the parts off the buildplate with the extruder.
      The main reason behind this project was to bring really cheap FDM automation to the masses as I have a background in building expensive belt 3D printers and I thought that there has to be a better and cheaper way to do this.
      1. Thanks dude this is interesting as fuck. Also, something to até least keep an eye open. When the nozzle goes up and is close to the top. The filament gets loose. There might happen 2 things. It may break if it is not new or the spool can get a knot. Both are issues for the continuous print jobs. Have you ever seen something like this happening?
Leave a Reply to Gregg EshelmanCancel reply
