Super-Portable, Tunable VHF Antenna
Ham radio is having a bit of a resurgence these days, likely due to awards programs like Parks on the Air (POTA) and Summits on the Air (SOTA), which encourage amateur radio operators to head outside and “activate” at various parks and mountaintops. For semi-mobile operations like this, a low-power radio is often used, as well as other portable gear including antennas. In the VHF/UHF world, the J-pole is a commonly used antenna as well, and this roll-up tunable J-pole antenna is among the most versatile we’ve seen.
The antenna uses mostly common household parts which keeps the cost down tremendously. The structure of the antenna is replacement webbing for old lawn chairs, and the conductive elements for the antenna are made out of metallic HVAC tape which is fixed onto the chair webbing after being cut to shape. The only specialized parts needed for this is a 3D printed bracket which not only holds the hookup for the coax cable feeding the antenna, but is also capable of sliding up and down the lower section of the “J” to allow the antenna to be easily tuned.
As long as you have access to a 3D printer, this antenna is exceptionally portable and pretty easy to make as well. Although VHF and UHF aren’t too popular for POTA and SOTA, portable equipment like this for the higher frequency bands is still handy to have around when traveling or operating remotely. With the antenna situation sorted out, a DIY radio that can make use of it might be in order as well.
6 thoughts on “Super-Portable, Tunable VHF Antenna
    1. I always find those finicky to tune, especially when you want to get decent SWR for both bands. The adjustable feed point on OP’s design makes this a non-issue.
  1. I’m confused by this article:
    “The antenna uses mostly common household parts which keeps the cost down tremendously. ”
    Antennas are cheap if you make them yourself. This is pretty universal.
    Commercially made antennas are stupidly expensive.
    Only a couple of antenna types have “expensive” components, magnetic loops require a capacitor that supports high voltages for instance. Even then, I bought a trimming capacitor for under $50, and expect the worst case to be under $100.
    SOTA & POTA might have some popularity, but I can’t imaging it moved the need much on initiating interest in the hobby. Cheap available handhelds likely moved the needle more, toss in other radios from China as well. Baofeng & Retevis as a couple of brands.
    All in in the content; just seriously wondering about the framing.
