Falling firmly under the fascinating science category of ‘What if…?’ comes the idea of powering airplanes with beamed microwaves. Although the idea isn’t crazy by itself, since we can even keep airplanes flying using just solar power (though with no real useful payload), running through the numbers as [Ian McKay] does in a recent article in IEEE Spectrum makes it clear that there are still some major hurdles if we want to make such a technology reality. Yet is beamed microwave power that much more far out than other alternative ways to power aviation?
Most of the issues are rather hard limits with the assumed technology (phased microwave arrays), with the need for 170 meter diameter ground transmitters every 100 km along the route (including floating transmitters on the oceans with massive power cables, apparently). Due to the limited surface area on something like a Boeing 737-800 you’d need to cram the full take-off power needs (~30 MW) on its ~1,000 m2 surface area available for receiver elements, or 150 Watt per rectifying antenna (rectenna) element assuming a wavelength of 5 cm.
The good news is that the passengers inside would probably survive if the microwave-like shielding keeps up, and birds passing through the beams are likely to survive if they’re fast enough. It’d ruin a whole part of the local radio spectrum from leaked microwaves, of course. Unfortunately beaming MW levels of microwaves across 100 km is still beyond our capabilities.
After this fun science session, [Ian] then looks at alternatives like batteries and hydrogen, neither of which come even close to the energy density (or relative safety) of commercial aviation fuels. Perhaps synthetic aviation fuel might be the ticket, but at this point beamed microwave power is as likely to replace aviation fuel as batteries or hydrogen, though more likely than countries like the United States building out a fast & cheap high-speed rail network.
I guess 5G giving cancer is not a problem anymore.
30 MW for take of power? Like a small city’s?
Oh I would be quite a late adopter to this technology. That is a bit too much power density in the air. I mean I assume it uses on-board power for take off, could be wrong
I’m not sure how you can be a “late adopter”, unless you move to a part of the world where this is outlawed.
Yeah I don’t see that being practical short of using a battery/supercap to provide the surge power needed for takeoff.
Planes are big, and the ones worthy of our attention have pretty significant minimum takeoff speed.
Cruising power requirements will inherently be much lower.
Navy style catapult.
Oops! Forgot the smiley!
Reminded me of an article in this edition that, for no discernable reason, I remembered reading: Popular Science, January 1988, “Beam-Power Plane”, “First actual flights”
https://mr-magazine.com/products/popular-science-magazine-beam-power-plane-january-1988-121517nonrh
I think battery powered planes are more realistic than this microwave beam stuff:
https://www.chinadaily.com.cn/a/202406/25/WS667a5675a31095c51c50ab4d.html
Microwaves beamed at an airplane to power it ? At least the food will be hot when it’s served….
https://en.wikipedia.org/wiki/World_Wireless_System
Probably one of those textbook green technologies where the unintended effects end up being worse than the tech it is trying to replace.
Indeed. Let’s put even more energy into the atmosphere. The attenuation effect turns that RF into nothing but heat. It’s small, but we are talking MW here. Not to mention the spectrum problems of all that RF flying around.
Can it be done? Sure. Should it be done? ……eh…… gonna have to go with a hard “no” on this one.
The fusion electricity seems more probable:)
Is the problem with scattering of microwaves in water vapours e.g. clouds and fog solved? And the part about enough quick birds is particularly ridiculous:)
We already have wireless transmission of fusion power.
We put those big black rectangles on our roofs to receive it.
“birds passing through the beams are likely to survive if they’re fast enough.”
Dateline S.E. Asia 1970:
One of the morning rituals was picking up “fried” birds under the tropospheric antennas.
“Haunted Airways”, Thomas Burtis. 1930.
All good until the Apache helicopter pops up and the pilot doesn’t spot the automatic weapons lock.
There’s a fascinating rabbit hole around the concept of scalar waves.
1x of them is basically undetectable (no fear of birds getting fried).
2x of them with a different frequency can deliver large amounts of energy to the intersection.
Ok, who let the Belkan runs freely again?
