OSHW Model Rocket Kit Embraces The Hexagon
If you’ve ever built a model rocket, you’ll know there’s not a whole lot to them. Essentially it’s a cardboard tube, a plastic nosecone, some fins, and a little clip that will keep it riding the launch rail as it accelerates off the pad. Extra points awarded if you add in a parachute, but strictly speaking, even that’s a luxury. Stick an Estes motor in that thing and send it.
But pointing out that lightweight cardboard tubes can be tricky to ship without getting crushed, [Concrete Dog] has come up with HEXA, a clever model rocket kit that uses pre-scored cardstock instead. The immediate advantage is that this allows the rocket to be shipped as flat sheets of material, but as a secondary bonus, once folded into its final shape the rocket has an awesome hexagonal cross section.
HEXA is certified Open Hardware
As with a traditional kit, both the nosecone and fins are plastic. Except here they’ve been 3D printed in either PLA or PETG depending on their proximity to he hot and fiery area of the rocket. [Concrete Dog] says the printed parts are largely ready to fly as-is, but that some quality time with a piece of sandpaper and a coat of paint could improve the aerodynamics a bit if you were so inclined.
Ready for the best part? [Concrete Dog] has decided to release all of the design files for the rocket under the CERN Open Hardware Licence, meaning you’re free to reproduce and modify the rocket as you see fit. In fact, on July 24th, the HEXA rocket was officially certified as Open Hardware by the Open Source Hardware Association (OSHWA) — a first for a DIY rocket, as far as we can tell.
22 thoughts on “OSHW Model Rocket Kit Embraces The Hexagon
      1. It means you aren’t tied to a fixed length of motor. So I can fly estes b6 stuff but also Aerotech D composite in 18mm. You can’t do that with an internal thrust ring set up.
        1. Most high-power rockets don’t use an “engine block” or thrust ring or whatever; without one, different lengths of motors can be used. With a 38mm motor mount tube, a rocket can be flown on a 6″ long H motor or a 20″ long J motor. The motor itself has an aft thrust ring.
    1. Over on this side of the pond that isn’t legal. Well you can technically do DIY hybrids but its a bit small for that.. but yeah solid rocket motor DIY illegal here.
  1. I like the hexagon concept and an excuse to use the 3d printer!
    As a parent that showed his kids the joy of model rocketry a couple years ago I consider the estes kits to be fairly affordable. A 30 USD starter kit had two rockets, a launch pad (where the puny rod broke on assembly so i spent 4 usd on two steel rods. Sorry i don’t remember the diameter) with all the peripherals we were in for about 50 USD.
    But now the cost to time ratio was great, we had approximately two hours per rocket on assemly and we had two launch days with friends and grandparents. I also had several days of “bird watching” with the binoculars to see if the one that blew into a 40 ft tree had dislodged in the wind and rain.
    For activities available with kids on the commercial side i rank it slightly more expensive than a video game and much less expensive than hobby RC vehicles or robotics. Less expensive than going to a movie or going out to eat. More expensive than playing with sticks, mud, and rocks by the river.
Leave a Reply to prfesserCancel reply
