G4 Mac Mini Is A Wolf In Apple IIc Clothing
A beige computer monitor with a green glow sits atop a flat, beige Apple IIc with a mouse next to it on a dark wooden table. A vase full of bright pink flowers is in the background.
Restomods let us relive some of the glory days of industrial design with internals that would blow the socks off the original device. [Mental Hygiene] decided to update an Apple IIc with a G4 brain.
Starting with a broken IIc, they pulled the internals, including the venerable 6502, and transplanted the parts from a G4 Mac mini into the case. There was plenty of room for the small desktop and its power supply. We love how they were able to repurpose the 5 1/4″ floppy access on the side of the IIc as a DVD drive.
A Mac OSX install DVD peeks out from the disc slot on a beige Apple IIc. You'd never guess this was originally a floppy drive.The original keyboard was adapted with an Arduino Teensy into a USB unit for the mini, but the internals of the mouse were replaced with a modern USB laser mouse running the signals over the original connector. What really sells this particular restomod is the “VGA adapter that outputs monochrome NTSC via RCA” allowing a vintage Apple CRT to make this look like a device that somehow upgraded all the way to OSX.
This mod looks to be from 2012, so we’re wondering if it’s time someone did this with an Apple Silicon mini? We’ve previously covered a few different minis inside G4 iMacs. We’ve even seen someone tackle the Compact Macintosh with an iPad mini.
4 thoughts on “G4 Mac Mini Is A Wolf In Apple IIc Clothing
  1. um, it’s a 65C02, perhaps that’s a bit pedantic, but it was fairly important for Western Design Center (WDC), which is sill around, offering a variety of updated chips based on 6502, and cores for FPGA.
  2. A giveaway that this is 2012 is that it’s not a Raspberry Pi (which had just come out). It’s been fairly obvious since to replace innards with a Pi ala PiDPs 8 and 11, or even a Pico W instead of a full Pi. Apple Silicon is suggested at the end, and frankly, seems to be the only point of necroposting this project, but I think makers are disillusioned with Apple and there’s no point in keeping continuity for Apple loyalty’s sake. It would be ironic to use MiSTer, particularly the new “Mister Pi” boards, because they can’t emulate an Apple IIc yet, afaik. But, please, no M1s, no transplated iPads, and preferably Open Hardware mods only please, so we can party like it’s 1999!
  3. Ah 2012.. ‘member the whole Aztec calendar apocalypse scare? Simpler times. It’s a bit of a necropost but it’s well-done and I like seeing modern(ish) macOS on a monochrome green CRT, that’s kinda fun
Leave a Reply to cuvtixoCancel reply
