Claroty’s TEAM82 has a report on a new malware strain, what they’re calling IOCONTROL. It’s a Linux malware strain aimed squarely at embedded devices. One of the first targets of this malware, surprisingly, is the Iraeli made Orpak gas station pumps. There’s a bit of history here, as IOCONTROL is believed to be used by CyberAv3ngers, a threat actor aligned with Iran. In 2023 a group aligned with Israel claimed to have compromised the majority of the gas stations in Iran. IOCONTROL seems to have been deployed as retribution.
There are a few particularly interesting aspects of this malware, and how TEAM82 went about analyzing it. The first is that they used unicorn to emulate the obscure ARM platform in question. This was quite an adventure, as they were running the malicious binary without the normal Linux OS under it, and had to re-implement system calls to make execution work. The actual configuration data was encrypted as the data section of the executable, presumably to avoid simple string matching detection and analysis.
Then to communicate with the upstream command and control infrastructure, the binary first used DNS-Over-HTTPS to resolve DNS addresses, and then used the MQTT message protocol for actual communications. Once in place, it has the normal suite of capabilities, like code execution, cleanup, lateral scanning, etc. An interesting speculation is that the level of control this malware had over these gas pumps, it was in a position to steal credit card information. This malware family isn’t limited to gas pumps, either, as it’s been spotted in IoT and SCADA devices from a whole host of vendors.
Bit-unlocker
We have another attack against TPM backed Bitlocker full disk encryption. The idea here is that by default Bitlocker uses an encryption key provided by the system’s Trusted Platform Module (TPM). Unless the user intentionally turns on Bitlocker PIN, this key from the TPM is the only credential needed to decrypt the drive, and is automatically provided at boot time. We’ve covered one attack against Bitlocker, where the key is sniffed while it’s being transferred from the external TPM. The conclusion as of that coverage was that a firmware TPM saves you from this attack, since there’s no accessible bus to sniff data from.
Well. There’s another approach, as you might have guessed. Modern memory requires constant refreshing to not lose its value, but that doesn’t mean that it’s entirely lost immediately. That’s what [Jack Crouse] discovered, and put to work here. Using the reset pins on a motherboard, the system is reset and booted off a flash drive. That drive contains a very minimal EFI application that just reads system memory and dumps it to the flash drive. Because the memory is mostly intact, if you reset the machine at the right point during boot, the memory dump includes the disk encryption key, allowing for easy drive decryption. If nothing else, this should be your queue to add a PIN to your Bitlocker setup. This was also a talk given at 38c3, which is now available!
Stars for Sale
GitHub stars are a useful way to determine the popularity of a project, and by extension how trustworthy that project is. At least, that’s the idea. Like any measure of popularity and trustworthiness, the GitHub Stars system has been gamed. Given how easy it is to create a GitHub account, and that giving out stars is a free action, it’s not surprising. The research suggested that between 3 and 4.5 million stars were fake, and GitHub has been quite responsive at removing the accounts and stars that are very likely to be inauthentic.
The Downside to a Connected Car
In a tale that gets worse the more you think about it, it’s revealed that 800,000 Volkswagen electric vehicles were leaking their precise information history via an unsecured Amazon storage instance. This wasn’t explicitly referred to as an S3 bucket, but we’ll use the “bucket” term for ease of discussion. This was discovered via an unnamed whistleblower, so it’s unclear whether the bucket name was accidentally made public. Regardless, it was accessible without any authentication. The broader question is why VW needs to keep these records on their drivers. It’s the downside to an always connected car.
How’s the Passkey Doing?
[Dan Goodin] is no stranger to the pages of this column, and he has thoughts about Passkeys. This isn’t a vulnerability — the FIDO2 specification hasn’t been broken in some new and clever way. Passkeys are still a good, secure way to use a trusted device as an authentication source. The problem is, they’re sort of a pain to use. Say you’re using Google Chrome on an Apple device. A site prompts you to create a passkey. Is that passkey managed by Apple, or Google? The answer is, by Apple, unless you explicitly ask Chrome to manage it. And then, Chrome on Mac isn’t allowed to sync Passkeys to Chrome on an iPhone.
And those are essentially the two problems with Passkeys: Every vendor wants users to use their platform to store passkeys, and once stored it’s devilishly difficult to manage and move passkeys to another device/platform. The silver lining is that many password managers can act as a Passkey store, and handle syncing between devices. But then again, there’s not much difference between passwords and passkeys, when you use a password manager to handle them.
Double-Click-Jack
And in related news, there’s a new approach to harvesting unintended clicks. Clickjacking is what happens when a site loads an advertisement at the top of the page, just as you’re trying to click on something, and your click gets hijacked to something else. Browsers have added protections to make truly malicious clickjacking harder to pull off. But Doubleclickjacking neatly sidesteps all of them. It’s simple: Launch another tab that claims to be a captcha, asking the user to double-click to prove they are human. Close the tab after a single click, and the second click goes to a different window. It’s clever and devious, and one more thing to watch out for.
Bits and Bytes
The US Treasury has reported that it was breached, via the ironically named BeyondTrust remote support vendor. It’s reported that this was an APT affiliated with the Chinese government, though very few details are available.
The intersection of data scraping and AI writing has led to dangerously good targeted phishing emails. Part of the danger here is that so much of the legitimate emails that spam filters are trained on are also written by LLMs, and executives are so used to that style of message, phishing emails fit right in.
[Mateusz Jurczyk] has released part five of the Windows Registry deep dive over at Google Project Zero. This installment is all about how the data is actually encoded into the registry files, as well as how those files are loaded and verified. Good stuff.
With U-Block Origin I never see a pop up or silly stuff. Never pay for gas with anything but cash. All of our gas station-convenience stores are run South Asians so less trust there. India in Indiana?
Uhhh. Welcome to earth!
Well, the double-click captcha claims “to verify your[sic] human.” That should be a dead giveaway.
I haven’t watched the talk yet but is this maybe related to
– https://www.ccc.de/de/updates/2024/wir-wissen-wo-dein-auto-steht
– https://media.ccc.de/v/38c3-wir-wissen-wo-dein-auto-steht-volksdaten-von-volkswagen
LOL@HaD.
You Link to
https://arstechnica.com/cars/2024/12/whistleblower-finds-unencrypted-location-data-for-800000-vw-evs/
which leads to
https://www.motor1.com/news/745636/vw-group-location-data-exposed/
with plenty of links but none to the mentioned actual sources (Spiegel & CCC)
(see above,) https://www.spiegel.de/netzwelt/web/volkswagen-konzern-datenleck-wir-wissen-wo-dein-auto-steht-a-e12d33d0-97bc-493c-96d1-aa5892861027
Well, I need to correct myself:
Motor1 does link to the sources – but not in the text with plenty of links…
Saying that there is little difference between a password manager supplying a password vs a passkey is a little bit shallow.
The passkey does provide a higher level of phishing / MITM resistance.
With the tradeoff that a passkey is less secure against database breaches on the server side, because (AFAIK) the secret can’t be stored hashed, only encrypted.
This is why two-factor is interesting, and why you need both factors: because it protects you against compromises in transit (oath, 2FA, passkey, etc) and compromises of the host database (a good solid password).
Passkeys uses asymmetric encryption.
The server holds the public key, so there’s no issue if it’s leaked.
The server sends a challenge, and the browser responds by signing it with the private key. The server verifies it with the public key.
I’m convinced that Range Rover has a database of all its newer cars available unencrypted somewhere, including where they are parked right now, where the tracker is, and whether the keys are still inside. I’ve heard of a few Range Rover thefts where someone has just walked up to a car with the keys in it and driven off (and removed the supposedly hidden tracker shortly afterwards). It can’t be opportunists glancing inside as they walk by because one of these cars was in an obscure enclosed drive way miles from anywhere, and stolen in the middle of the night. CCTV showed the thieves walking directly to the car – they knew exactly where it was parked, and must have known the keys were in it. (I don’t know why someone would leave their keys in their car, let alone a Range Rover.)
Well with rfid and nfc in pretty much a lot of devices you could easily just use a rfid chip or microcontroller with a coin cell and solar panel (smart to use a rechargeable battery or capacitor)
The host device (or network admin) that wants the security clearance would use an offline device to generate a key set, using rolling codes, and can even use a seed based on the users password, allowing for built in 2fa, and generate hashes and checksums, this would have to be decrypted by the system being access and queried for clearance, the password is used to verify the hash and checksums as a valid user, and the hash and checksums once decrypted can be checked against a keyset to verify clearance and that the hash is a valid one generated by the host system.
This pretty much would kill any mitm attack of the rfid signal as the attacker would just see random encrypted garbage sniffing raw radio packets.
And the verification and decryption can only be done on a host system set up specific to the task, no private keys are ever sent outside the cpu or asic bus encrypted or decrypted, even the private key sets can be stored on disk as encrypted hashes, using a on die encryption key, so you only feed the encrypted hash, checksums, user password/id, and private key hash
And you only get a valid output handshake or invalid rejection from said processing
Nowadays you can fit easily several megabytes of lvl 0 cache, store keys using efuses or otp, and obfuscate the efuses/otp from the main bus using effectively embedded microcontroller to do the cryptography so the cpu never touches the unencrypted raw private keys
So it doesn’t even know what the “cpu key” is
Works on cars and access doors too
Easy to whitelist or blacklist
Just delete keys and user id
