Growing Semiconductor Layers Directly With TMDs
Schematic for progress of 3D integration. a, Schematic showing conventional 3D integration by TSV through wafers. b, M3D integration of single-crystalline Si devices by transfer, c, Growth-based M3D integration of polycrystalline devices. d, Growth-based seamless M3D integration of single-crystalline devices. (Credit: Ki Seok Kim et al., 2024, Nature)
Transition-metal dichalcogenides (TMDs) are a class of material that’s been receiving significant attention as a possible successor of silicon. Recently, a team of researchers has demonstrated the use of TMDs as an alternative to through-silicon-vias (TSV), which is the current way that multiple layers of silicon semiconductor circuitry are stacked, as seen with, e.g., NAND Flash ICs and processors with stacked memory dice. The novelty here is that the new circuitry is grown directly on top of the existing circuitry, removing the need for approaches like TSV to turn 2D layers into 3D stacks.
As reported in the paper in Nature by [Ki Seok Kim] and colleagues (gift article), this technique of monolithic 3D (M3D) integration required overcoming a number of technological challenges, most of all enabling the new TMD single-crystals to grow at low enough temperatures that it doesn’t destroy the previously created circuitry. The progress is detailed in the paper’s schematic (pictured above): from TSV to M3D by transfer of layers and high- and low-temperature growth of single-crystal layers.
Ultimately, the demonstration device with vertically grown transistor arrays (nMOS and pMOS) on a silicon substrate was grown at 385℃, which, if commercially developed, could mean a significant boost in transistor density and possibly the development of 3D semiconductor circuits rather than stacked 2D ones. We are still worried about making them the old-fashioned way.
5 thoughts on “Growing Semiconductor Layers Directly With TMDs
  1. So this is a technique to crystallize arrays of gates on top of existing layers as just new steps in the process so you can just keep building up and up? Is that right?
      1. Totally True, but if one T-800 has it in 1991, should not another T-800 in 1984 not also have it in 3D ?
        And the hook of the melody is basically the same.
