Sheet Metal Forming With 3D Printed Dies
Sheet metal is very easy to form, including the pressing in of intricate shapes with dies and a hydraulic press, but the dies themselves are slightly harder to come by. What if we could 3D print custom dies to stamp logos and more into sheet metal? This is the premise of a recent video by the Stick Shift Garage channel on YouTube in which dies are printed in PLA+ (solid infill) and used to stamp 1 and 2 mm thick sheet metal with the channel’s logo.
As can be observed in the video, the results aren’t bad at all after a couple of tweaks and adjustments to the pressure, but of course there is room for improvement. Some helpful commentators suggest improving the dies with properly rounded edges on the die’s shape and paying attention to K-factors and kin so as not to overstress or tear the sheet metal. In terms of die longevity, the PLA+ dies began to wear out after about a dozen tries but not the point of failure. Here other filament types might work even better, maybe even to the point of competing with a CNCed metal die.
Considering that this was a first attempt without a lot of pre-existing knowledge it went pretty well, and a future video was promised in which improvements will be shown off.
16 thoughts on “Sheet Metal Forming With 3D Printed Dies
  1. If the PLA is used to make a mold for a plaster pattern for casting zinc alloy dies, many thousands can be made from a single die. The printer sidesteps the WW II wooden pattern making. Such dies would make around 15,000 fuel tanks before they wore out. Which was generally more than they ever made before a new air plane model went into production instead.
    1. Agreed, though I have little experience doing this myself, and that was quite some time ago. For low yield/hobbyist use what alloys would you suggest today? Zamak 3?
  2. With things like this, where you could imagine plenty of ways to maks the tool, the helpful part is just seeing examples of what works.
    For instance, I wouldn’t have the patience to print anything with solid infill – but knowing that this works, I would be confident to try a hollow PLA part filled with resin or plaster.
    1. As Reg mentioned earlier, the right next step it to do a zinc casting, so it is indeed completely unnecessary to print an entirely solid part. Though I do caution going too thin on the face layers to minimize defects and ease preparation, no point in saving print time only to have to spend it manually fixing the blank.
  3. People have been doing this for quite a while now. I’ve seen examples of it 2+ years ago, why is it just now a hack? and yes it was submitted back then
  4. Should anneal the aluminum. I’ve stamped copper and brass, annealed, doesn’t punch thru, but could be die clearances.
    1. Copper and brass work harden. Aluminium does not.
      At worst case scenario one could ruin the original heat treatment + aging which is essential for retaining the original properties of the aluminium alloy.
      1. Aluminum does work harden. The definition of T2, T3, and T8-T10 tempers, for example, requires cold working inbetween or after heat treating steps. Non-heat-treating alloys like 3003 are worked exclusively (H temper).
        Low-melting alloys, particularly tin (it’s complicated) and lead, experience significant diffusion at room temperature and therefore do not permanently work-harden, or as significantly as other alloys.
  5. I started playing with this and was surprised by how much I could get out of 3d printed dies if I was careful. I could produce hemispheres the size of ping pong balls out of 24 gauge galvanized steel with minimal damage to the dies. This is an area that I really think people should mess with more. We don’t have to be limited by bends: we can stretch metal into compound curves, and it’s not even difficult.
Leave a Reply to the gamblerCancel reply
